Question about Canon IMAGERUNNER 3530 Copier
Paper jam at the fixing unit for IR 3530
When you make copies the paper always jam at the fixing unit
  • Canon Master
  • 1,294 Answers
Check the exit sensor actuatir and the the fusing unit upper and lower roller strippels.
Posted on Apr 20, 2013
muleskinner2
  • 270 Answers
SOURCE: repeated paper jam in the fuser unit
There could be two problems with the copier:
1. There has been a Canon mod for the two pads already suggested earlier. Remove the two pads and place a foam strip that is runs across the top of the lower right access door basically between those two pads. This creates more even pressure across the deflector for the upper paper cassette.
The style of roller above the exit for the paper cassette is now gray in color instead of black.
Posted on Nov 13, 2007
canontech
  • 1219 Answers
SOURCE: my ir 3300, always get a jam paper, how i cant fix
Where does jam occures?
In fixing section, in duplex, in paper tray,...
Please be specific!
If you want service manual, or further help, you can contact me on emma.servis@gmail.com.
Posted on Jul 10, 2010
  • 92 Answers
SOURCE: canon ir 2016 digital copier
you can have 1 of 2 problems.
the cassete paper are in A4 position ,or you can trie to clean the registry roller.
Posted on Nov 02, 2009
canontech
  • 1219 Answers
SOURCE: IR4570 paper jams at fixing unit whenever i try to
first clean all rollers espc. below the drum unit two rollers on axis, if the paper comes out bent in the roll open fresh pack of paper because of moisture, when you open the right door above fixing unit you will see one more small door that is loosen, on these inner door you will se long plastic flapper ( ussually black plastic with small picker fingers ) that is connected to solenoid, these flapper has on both sides some kind of sponge sticker on left and right space where it touch the inner door - REMOVE THEM.
Hope that helps!
For service manual write me on emma.servis@gmail.com
Posted on Sep 09, 2010
SOURCE: false jamming at duplex unit
IT THE BIPASS ROLER THAT IS NOT PICKING THE PAPER
Posted on Jan 10, 2011
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
JAM ERROR 0207 ON CANON IR 3530
Open the printer and remove the paper jam.
Dec 04, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Hello , i have cannon IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
Open your developer unit and check sensor , refix it an close unit see........your problm solved
Apr 22, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Hello Sir, I have Canon IR 3530 Machine, it is not work properly when i am trying to Photocopy of document but when i am taking documents copy than it is not possible for me. My machine becoming very hot...
as I understood, your copier is getting paper jams and heats too much.
The problem can be in the fixing heater. Probably he is heating too much, but in this case you would get error code like E001.
You better call service this problem is hard to resolve by this way...
Aug 23, 2011 | Canon Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
In my 3530 single side copying is ok but when i am trying for back to back my A3 paper is getting jam with z fold pls guide
are you talking about ir 3530 b&w copier?
"Z FOLD" of jamed paper is usual when paper goes from cass. towards registration roller, and registration clutch doesnt operates.
Do you have problems with A4 double sided too?
Where does the jam occures? In wich section?
I had few cases, when the paper stucked above fixing unit in small inner door, wich guides paperout or back in duplex, for second side copying.
The problem was in spring and solenoid wich lifts the paper guide plastic with finger.
It also could be case that you need to replace paper pickup, feed and separation roller in cassete where is A3 paper, and clean other rollers.
Try to put paper in "good" cassete, from wich you do not have problems.Just swap papers, and set correct paper sizes, and if it works then the problem is 70% in rollers.
On the place where the paper stucks, clean the paper rollers, by rotating it and cleaning with alcohol or water and dry it verry well.
Hope that helped.
If you have more questions or want service manual, write on emma.servis@gmail.com
Jul 09, 2010 | Canon Office Equipment & Supplies
When i start to print it always gives me paper jam and print fain
Clean beeneth copy glass and even the laser unit.
How many copies do you have with present drum unit?
If over 50000 copies change the drum too.
May 25, 2010 | Canon iR 2016i Black and White Copier
CANON IR2016
hi... try to clean up your copier... usually dust accumulates inside the copier that's why paper inserted will always jam....always see to it that you copier is free from dust and other small particles that would cause your machine to get errors....
Feb 27, 2008 | Canon PC-940 Black and White Copier
ERROR c-6000
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
Jan 26, 2008 | Kyocera RI-3530 Black and White Copier
337 people viewed this question
old marine
old marine
