Question about Peavey Electronics Peavey Max 112 Bass Guitar Combo Amplifier
I have a peavey 112 max bass amp and every time i turn it on it sounds great for about 3-5 mins, and then it loses a lot of power/volume. What's going on?
Any help would great. thank you
3 Suggested Answers
  • 5603 Answers
SOURCE: Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Posted on Sep 22, 2009
  • 5603 Answers
SOURCE: I have a Peavey MAX
The amp is doing what is called "motorboating". This is usually caused when the voltages to sensitive preamp stages are inadequately filtered or regulated and the sudden load of the output stages cause a dip in the voltages sent to the preamps which in turn vary the input to the output stages starting the cycle over. This will require electronic troubleshooting and if your not skilled in that, then it is NOT a DIY fix. What you are seeing is NOT normal, there is a defect.
Posted on Apr 23, 2011
Peavey bandit 112
have you tried using a foot pedal? Are you sure it is switching (green light turns red, etc?). On the lead channel are you turning up the gain all the way and the volume down?
Oct 12, 2013 | Music
Peavey Problems
Check speaker impedance or disconnect speaker leads, then use a 9V battery to verify cone movement and if this test is ok, then go inside the amp, if there's no fuses blown check opamps supply voltage which should be -15V at pin-4 and +15V at pin-8, let me know your results to help improvement.
May 21, 2013 | Peavey Electronics Peavey Max 112 Bass...
My peavy amp will not turn on
1- check the outlet for power by plugging in a lamp or something
2- check the amps fuse. Most power amps have user replaceable glass fuses.
Aug 17, 2012 | Peavey Bandit 112 Guitar Amplifier With...
Peavey decade manual
Recommend an Ashdown or Fender with a 15" speaker, they will give a good sound, are gig-worthy, and will last. I use a Behringher 120W for rehearsal work, it only has a 12" speaker and thus cannot give a good 'presence', also I have been reliably informed, a lot of custom chips are used in thier amps.
Don't forget, a bass 'E' goes down to something like 60Hz, and a good speaker and amp are a must for bass work
Feb 12, 2012 | Peavey Music
I have a Peavey MAX 112 Bass Combo amp. When I turn on the amp and have it plugged into the cord and bass, it immediately begins emitting a "whump whump" sound similar to the sound a beating...
Apr 22, 2011 | Peavey Electronics Peavey Max 112 Bass...
NEED SKYMATIC DIRGRAM FOR PEVEY 112 AMP TH E AMP WORKS FINE FOR A WHILE THEN IT HAS A VERY LOUD POP AND QUITS, JUST TURN IT OFF FOR 4 OR 5 MINS. AND IT WORKS GOOD A GAIN. I DO SUPECT THE OUT PUT...
USUALLY if the output transistors go, they stay gone. You may have a thermal cutout switch shutting off because of over temp. Make sure fans and heat sinks have free air flow. I have seen broken solder joints in these near the volume pots. Those can also cause a failure as unit warms. When it stops again, let it sit without playing for say 10 minutes and see if it comes back on... if it does, the over temp sensor is probably shutting it down so it doesn't fry. Is it possible you are driving it too hard? Often people try to get more sound level out than unit can deliver.
Apr 22, 2011 | Peavey Bandit 112 Guitar Amplifier With...
Sep 19, 2009 | Peavey Music
Peavey Electronics Peavey Max 112 Bass Guitar Combo Amplifier Logo
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
