Question about Craftsman Garden
No get up & go
Model 917276702 24 HP 48" End of last season - my tractor had a hard time pulling a small grade. It's about 5-6 yrs old - hasn't been abused, but I figured it was about time for a tune up. Had Sears come out last week & tune it up - it's still has little pep. When I mentioned it to the tech - he said the transmission might be going. Really - I thought tractors lasted alot longer than 5-6 years. Need some help - any ideas why it's so sluggish? Thanks
    Master:
  • Craftsman Master
  • 645 Answers
This unit runs a Hydro-Gear transaxle. These are normally pretty good units. Have the service guy check the fluid level and belt a stretched belt can also cause this issue.
Posted on Jan 02, 2018
wadembly
  • 513 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
SOURCE: My Sears Craftsman Garden Tractor 22HP, dies after it gets hot
Sue your brother is right! I had the same problem and it turned out to be the gas cap. the small breather hole on the top was plugged with dirt. once I cleaned it out I took the rubber gasket out from the bottom of the cap and cleaned that as well. runs great now.
Posted on Jul 14, 2009
SeaDaddy46
SOURCE: Craftsman GT5000: Dies when switch is pulled to engage blades
I have the same tractor. If you have the transmission in <reverse> this will happen every time. It's a safety feature. Be sure the tractor is in <neutral> or one of the 6 forward gears.
Jim Romines
Posted on Jul 31, 2009
bargainbin2
  • 123 Answers
SOURCE: I have a john deere 430 garden tractor diesel.
Sounds like the fuel pump stoped working.
Posted on Aug 26, 2009
mowerman1857
  • 389 Answers
SOURCE: looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
Posted on Oct 22, 2009
Lawnmower trans?
Thr hydro is at the rear of the tractor so its hard to believe the oil has come from here up to the front, also they have a multi grade engine oil in them not transmission fluid, are you sure this machine is not in bypass mode ( push mode ) the oil is more likley come from the bottom engine seal, and quite possibly covered the belt making it slip.
Jun 21, 2013 | Garden
Tractor runs crappy and then dies once i put it in mowing mode
does it run a little better with the choke on part of the way? did you leave gas in it from last season?gas is only good for about 30 days in a small engine
Apr 28, 2012 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Yard tractor has 145 hours ran 2 weeks ago but was missing ,it had backfired,changaed plugs,fuel pump works,seems to get spark,won't start even eith gas put into cylinders
You may possibly need to adjust the overhead valves in the engine. Your owners manual should have the steps included in it (under maintenance) to do this. This is quite possibly the problem. The valves should be checked and adjusted once a season just to be sure.
Aug 12, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a 2cyl Mantis that has a problem. The pull cord pulls very hard. When I take out the plug the engine turns over ok. Was ok at the end of the last season, I drained it and put oil in cyllinder. What...
pull it a few times to get the oil out off the cylinder 2cycles dont run on heavy oil well put fresh plug
in with gas and oil and try again you did use oil and gas mix last year right
Jun 12, 2011 | Garden
After getting mower ready for the season, it started and would not move forward or backward. The free wheel control pin was pulled out and I pushed it back in and still it won't move.
Hello.
We've had several solutions lately on the hydrostatic transmissions, and usually, what you did would normally correct the problem. We have had one person report that the fully "IN" position did not correct the issue, but somewhere between the "IN" and the "OUT" positions was just right. In his case, the positioning rod was bent. Try various positions. You are on the right track.
Best regards, --W/D--
May 02, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Where is the oil filter on a 17 HP Craftsman briggs & Straten engine and what grade of oil do I need
It may not have a filter, but if it does it would be a small spin on type on the left side of the engine about 4 inches in diameter. Use SAE 30 in that engine. It takes about 48 ounces of oil. Sears sells 48 oz bottles or you can use oil from your favorite auto parts store. Just don't over fill or it will smoke. Verify level with dip stick screwed in.
Oct 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My Husqvarna LT1538D riding mower only charges the battery up to about 12.3 volts. So, I have to charge the battery, a new one, about twice to get through the cutting season. The dealer worked on it last...
On almost any engine you pull the flywheel and you will see the charging coil. Once out it can be tested by yourself or any competent electrician. Good luck. donnyb60
Mar 27, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
