Question about Harmon Kardon Harman Kardon Avr 325 7.1 Channel 65 Watts Per Channel 450 Watt Receiver
Need manual for harmon kardon avr 325 - Harmon Kardon Harman Kardon Avr 325 7.1 Channel 65 Watts Per Channel 450 Watt Receiver
When i turn on my harmon kardon avr 165 it shows ''Protect'' and then it turns off again?? what can i do :)
I would try disconnecting the speakers, then turn it on. If protect still shows with no speakers connected, then it needs to go to the repair shop- Might be a blown power transistor.
Oct 24, 2013 | Harmon Kardon Harman / Kardon AVR 165...
Hi, I have a Harmon Kardon Model No. AVR 325 that keeps clipping. When I push the power button the display turns off like a second after I push power. Seems like its a easy fix. Nothing if fried visually...
it sounds like Amp burned, but not all burn parts you can see, you have to measure them by DMM. I guess at least one AMP transistor shorted. you can check SPK terminals by DMM DC, it can be easy to find different with other one
Mar 19, 2011 | Harman Kardon AVR 325 Receiver
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
Harman kardon avr 325 fan motor is making a noise.
Fans are typically not serviceable. They die, they get replaced. Maybe you could look inside it and see if it has dust on it, possibly unbalancing it. Then you could assess the scope of removing it yourself. My guess is the fan may be a common variety available at Radio Shack, unless it has an internal sensor circuit for temperature or rotation speed.
Feb 12, 2010 | Harman Kardon AVR 325 Receiver
Need starchoice codes for Karman Kardon AVR 220
http://www.starchoice.ca/english/customercare/techcentral/remote_controls.asp
Look here for the codes to whatever remote you have. The chances are there arent any though. Harmon Kardon codes are a very unique signal that most remotes cant duplicate. More than likely you are going to have to use the original Harmon Kardon remote.
Oct 24, 2009 | Televison & Video
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
Shutdown during exciting audio
I have the same problem also. Customer service told me to double check all my cable wires to make sure there is no short. Heck I just went ahead and unplugged all the speaker wires and then it was fine. I replaced all speaker wires and it worked for a couple days but its starting up again. i did the hard reset like the manual told me to do but the same problem.
Thats what customer support told me to do. They said it could be because its going into a safe mode. Mine is just shutting down no matter what sound is coming out of the tv or movie.
Jan 20, 2008 | Harman Kardon AVR 325 Receiver
Harmon Kardon Harman Kardon Avr 325 7.1 Channel 65 Watts Per Channel 450 Watt Receiver Logo
158 people viewed this question
Top Harmon Kardon Audio Players & Recorders Experts
Rod
Rod
Lawrence Oravetz
Steve
Are you a Harmon Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
