Who makes the nr ctv5165 sil television - Televison & Video
What oil does an aztec ac1 compressor use?
It's a re-branded Werther Sil-Air compressor (15EAC) & uses Sincom 32/e oil that is supplied for Sil-Air compressors.
Jun 01, 2013 | Testors AZTEK A470 Airbrush Set A4702W /...
Sil on Display
1) clean with water and cotton.
2) see if there are result o.k
3) try to clean with little alcohol, and see if there are best result.
4) Otherwise you must contact your supplier manufacturer.
God bless you
Jun 28, 2012 | Exercise & Fitness
Tune my alba tv CTV 5105 SIL lost my remote want to tune to my ps3 Thanx
You'll most likely get a replacement from Remotes4U website cheaper than an original Alba, if indeed Alba can supply one.
Sep 21, 2011 | Televison & Video
Where is the vertical part of the Sony KV-XJ29M50, or what type of IC in that part?
Hello
Vertical output Ic is in the A board itsef. It is an SIL type [Single In Line type] Ic, screwed onto a metal heatsink to radiate heat out of it while working.
OK.
Jul 29, 2011 | Sony KV-XJ29M50 29" TV
Philips 28PW6006/05 locked after setting "NR" to Yes...
NR=Noise Reduction.
If set is locked you must use the parental code to unlock.
Aug 29, 2009 | Philips 28PW6006 28" TV
Recommended best settings for the TH-50PZ700U Plasma TV
Try this one and see if you like it!
Normal: No
Picture mode: Custom
Picture: +22
Brightness: +9
Color: -3
Tint: 0
Sharpness: 0
Color temp.: Warm
Color mgmt.: Off
C.A.T.S.: Off
Zoom adjust: (grayed out)
PC adjust: (grayed out)
-- Other adjust menu
Video NR: Off
3D Y/C filter: Off (grayed out)
Color matrix: HD (grayed out)
Block NR: Off (grayed out)
Mosquito NR: Off
Black Level Light
3:2 pull-down: On
HD size: Size 2
Dec 26, 2007 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
