Question about LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive
How do i get this thing to work i dont know how to set it up...no instructions
Need instructions
I dont know how to get the update.
Hi Leanna
i find it useful to go into settings on my devices, when things have something to do with the " insides" of the device.
  • find settings
  • Update or words of similar meaning
  • Click there and you will be informed wheather there is a program that needs updating.
  • Then follow the instructions
Aug 12, 2015 | Tablets & eReaders
I have lost instructions for my Auriol weather station-4 LD2920 can u help
i have a hand held acu-rite model 8550 and did not get any paper work with it and dont know how to operat it
Jan 05, 2013 | Measuring Tools & Sensors
I dont know how to setup my netgear i have got soo far but it dont work
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 27, 2009 | NetGear WGR614 Wireless Router
Lost instructions for bubble console pre school game
hi tim im having some problems with bubble at the moment its unreal i have some phillips codes dont know if they will work however ill give them to you anyway
0503 0539 0646 0671 0675 0854 0885 1158 1260 1267 1812 1813 1818 1911 1914 if you stick the set up dvd in n watch the first time set up bit it explains everythin you need to know i there hope this helps you out!
Dec 20, 2008 | Toys
Saeco idea
Yes, i have instructions to this machine.
Jul 14, 2008 | Saeco Easy Espresso Machine
Need operating instruction
I dont know where to find an instructions booklet but I can help with setting the time/date:
To set the time and date (you have to do them both together):
  • First press and hold the 'CLOCK' button until it beeps then let go.
  • You will then be required to select the year by scrolling up or down with the 'TIME SET' rocker switch on the right hand side.
  • Once you have the right time, press the 'ENTER' button, to the right of the rocker switch once.
  • You will then be required to select the the month. Do this by once again using the 'TIME SET' rocker switch and then pressing 'ENTER'.
  • You will need to repeat this to select the date (day).
  • You then use this same process to select the time, starting with the hour and then the minute.
  • After you have finnished selecting the minute, press the 'ENTER' button once and then the set time, with the day in the top left corner will be shown. You do not need to press anything else. Your clock is now set.
REMEMBER to press the 'ENTER' button after selecting each thing to move you on to the next thing to set.
TIP; Beside the 'CLOCK' button there is a button which says 'D.S.T SUMMER T'. This is the button which automatically switches your clock from british summer time to winter time and back again. It means that you do not need to reset your clock every time. Make sure that it is in the right setting when you set the clock otherwise it could get confusing. You will know if it is on british summer time because a small sun with a clock face appears in the top right corner of the screen.
Good Luck x
Mar 16, 2008 | Sony ICF-C273 Clock Radio
Open Questions:
See all LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive Questions
LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive Logo
56 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
