Question about Sony MDS-JE520 Mini Disc Player
Sony MDS-JE520 Moisture damage? by being left in a box in a cold garage, now carriage will not take in the minidisc
I left my minidisc, mixing desk and Echo unit all enclosed inside the flight case, in my garage, brought it from garage flight case catches/hinges were rusty, as was the outer metal cases of the units inside. everything lights up and appear to be working apart from the minidisc, It won't take a disc in, when you enter the disc into the carriage it would normally pull the disc in automatically, it just goes part way in, do you think this is an electrical or mechanical problem
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 236 Answers
It's kinda hard to tell from here.
I suggest you take the cover off and see what the mechanism looks like when you try to insert an MD.
I don't think there is any part that can rust, but something may have bent as it got cold and then hot and then cold.
Posted on Apr 26, 2013
Testimonial: "Thanks Eliezer, just to clarify, The rust is h]just corrosion in the outside of the underside of the minidisc unit, I've already taken the cover off exposing the internal circuit board etc, there is no damage whatsoever that can be seen on the inside, I can put the disc in and see the mechanism moving, but the disc does not automatically get pulled in, I can't force it in either, that's why I was asking the question is it an electrical control that takes the disc in all the way once it is physically put into the disc tray, or is it purely a mechanical problem, the disc player worked fine before being left in the garage, so I was thinking was it a dry joint(solder) or a mechanical problem that just needed some wd40 or similar. Hope that gives a better clue for anybody with better knowledge than myself. Regards to all TC "
5 Suggested Answers
dvdcdlaser
  • 1285 Answers
SOURCE: I have a Sony MDS JE520 mini disc deck. How do I
requirements needed....1 rca (red & white) cable to mini plug, a software http://audacity.sourceforge.net/ ......once downloaded software and your device is connected to pc mic in / audio in...audacity lets you choose a format to save your file (pick MP3) this will take up less space on pc....this will take a little time to get uss to so prcactice a bit. if your mini disc tracks already have gaps between them or not...once recorded audacity lets you edit what you just recorded..(you can fade out/in any part of the file)....hope this helps you do what you wanna do...feel free to rate the help
Posted on Jun 28, 2009
jansser
SOURCE: Sony minidisc MDS-JE320 Clicking problem
I had the very same problem with my MDS-JE510 and I found out that it has something to do with a sliding plate that comes forward and stops too far. It is a metal pin that could be bend (very, very little) to the frontside of the recorder. I put a paper between the pin and the stopplate and the problem was really gone. Now I bend the pin so it stops earlier and voila, everything works super fine. I can send a picture of the pin, I made. It's n the leftside of the disc-unit. The only thing you have to do is open the upper cover (5 screws). Tell me if you would like to send me the picture OK? Ronnie Janssen.
Posted on Nov 21, 2009
  • 4234 Answers
SOURCE: MDS JE520 Disc stuck in unit
the C13 is a mechanism error. The TOC means Table of Contents which is the part of the disk that determines the beginning of each track. These units are somewhat delicate and not really DIY repair candidates. Parts are still available for these. Look for either an authorized Sony service center or at least a shop that has worked on these in the past for repair assistance. The loading mechanism may need to be repaired or replaced.
Dan
Posted on Feb 03, 2011
SOURCE: Sony MDS-JE520 Mini Disc Machine no operation,
This is from my own experiance. I inadvertedly bent the cover of my deck and had the same error.
The minidisc is blocked in the loading mechanism. Too much weight on top of the deck can bend the cover and the metal support which is above the loading sledge. The slider is then blocked. When you connect the power you can hear a motor trying to move for as short instant.
Disconnect the deck from the power supply.
Take of the cover and check if the support is bent. carefully bend it upwards, if so. Reconnect power and check if the deck powers up..
That's my solution which worked for me.
BTW I second Obertellis advice to find a MDS-JE780 (or MDS-JB980) they are the most complete decks ever made by Sony
Posted on Oct 17, 2011
How do I reset my Sony mini disk MDS-JE520.
What does "reset" mean? Do you mean the Setup menu?
Sep 29, 2014 | Sony MDS-JE520 Mini Disc Player
Mds-je480 how do you set player to auto stop after each track
You can't. http://www.minidisc.org/manuals/sony/sony_mdsje480_manual.pdf
Apr 19, 2014 | Sony MDS-JE520 Mini Disc Player
MDS-JE520 player makes chattering sounds==do you repair? Please send details--Thanks-- BOB
The only repair place I know of in the USA is ProDigital of Philadelphia who repairs digital broadcast equipment and Minidiscs subject to parts availability.
520s are mostly worn out at this late date try to find a 630 which does all of the same things better and is a newer unit.
Jan 22, 2011 | Sony MDS-JE520 Mini Disc Player
Sony MDS-JE520 Mini Disc Machine no operation, standby led is illuminated, but pressing on/off button it does not respond
Jul 25, 2010 | Sony MDS-JE520 Mini Disc Player
WHERE CAN i BUY A REMOTE TO WORK WITH MDS-JE520
Hi, you can go to any sony shop around you or visit their site and check for the contact address to get the remote.
Take care.
May 18, 2010 | Sony MDS-JE520 Mini Disc Player
Sony mds-je520 on stand by led on bur cant tern on player
Make sure the "TIMER" "Rec"/"off"/"Play" switch is set to "OFF".
Then press power, and you should be in business as soon as it read the TOC on the disc. Without any disc inserted, it should go straight to being ready.
Apr 27, 2010 | Sony MDS-JE520 Mini Disc Player
Stuck disc
The carriage assemblies for these units are known to break. Please DO NOT attempt to remove the disk. Bring this to an authorized Sony service center. They should be able to give you a fixed price repair quote. This is the only way to save the disc and prevent further damage to the assembly. The replacement assemblies are a bit better than the originals so you shoudn't have this problem again.
I have repaired a number of these with much success. Care must be taken so that the disc heads are not damaged.
Keep us posted.
Dan
Jun 01, 2009 | Sony MDS-JE520 Mini Disc Player
I have a Sony MDS-JE520, NO SOUND!! but the rest seems to work
stick it up your *** 3 times and it will do the trick :D
Mar 20, 2009 | Sony MDS-JE520 Mini Disc Player
Sony MDS-JE520 Mini Disc Player Logo
59 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
