Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Part number for fuel shut off valve for Toyo laser 56
toyotech
  • 8 Answers
SOURCE: EE2 code for toyo LASER 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Posted on Jan 28, 2008
  • 22 Answers
SOURCE: Toyo Laser 56 EE2 message--no flame? valves open and clean filter
You might of got type 2 fuel oil. If it is a smaller tank sometimes the fueler doesn't clear the line before filling and you'll slug down some type2 which will snuff the flame.
Check to see if the filler kinked a line outside while filling.
Just an Idea...
Posted on Oct 23, 2009
  • 126 Answers
SOURCE: I have a toyo laser 56 stove. It is starting to
Pilot,
You need to have a new mat put in the bottom of the burner. When this mat lifts, sometimes the flame will cause a moaning noise with a large yellow flame. A new mat and maybe a burner ring will fix ya.
Tom
Posted on Feb 08, 2010
  • 126 Answers
SOURCE: We have a Toyo Laser , when it kicks on we get
Tubearz,
You need to look at the igniter guide gasket. That is the gray fiber gasket just behind the igniter flange. When you remove the igniter you may see a black rubber gasket that could be cracked or completely gone. You will need to replace it with the new style ( #17185580). While you are looking, look at the draft tube, where it goes into the fuel sump. If it is cracked it will need to be replaced.
Good luck,
Tom
  • 674 Answers
SOURCE: i let my tank empty
You may have an air bubble in the fuel line or the filter (if you have one at the fuel barrel) may be clogged. The filter has a vent screw on top and you may need to vent the filter to get the fuel flowing. There is also a strainer in the fuel sump that may have gotten clogged.
Another thing is to push the red float reset button on the right side of the heater. If the float is latched up you will feel a little resistance and hear the float drop. Only press the reset button momentarily. It is not a primer button.
You can get a bowl and some rags to set under the line where it connects to the back of the heater and then loosen the line to make sure you are getting kerosene to the heater.
The fuel pump makes a loud ticking or thumping sound if it isn't getting any fuel.
Let me know if this helps or you need more advice.
Posted on Nov 20, 2010
I let my tank empty before refueling and now my toyo laser 56 has a ee 2 error on it how can i fix this?
You should check the filter at your oil barrel if you have one there and loosen the small vent screw to bleed the filter and line. You can also check the strainer in the fuel sump but remember to turn off the fuel at the barrel before removing the strainer from the sump. Also press the float reset button on the full sump. You can loosen but not remove the fuel line on the back of the heater if needed to get the fuel flowing. Be sure to place something under it to catch the kerosene and have some rags handy.
Jan 03, 2011 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo stove laser 56 error EE56 what to do
I don't see an error code EE 56 in the service manual. Please verify the error code. What I do see is EE 6. This can be caused by several things. Most commonly a fuel flow problem or out of fuel. If you are out of fuel or the fuel just isn't making the fuel pump, the pump will make a loud ticking or thumping sound. You should check your filter at the oil tank, if you use an external tank. You should also check the strainer in the fuel sump located on the right side of the heater. Two screws hold the cover on. You need to turn off the fuel valve at the tank and have some rags to soak up the kerosene that will come out when you remove the two screws. Take the top off the fuel sump and inspect it also. Kerosene sometimes gels up after sitting a while. The fuel nozzle also gets clogged with carbon from time to time. You can clear this by removing the fuel line from the combustion chamber and inserting a piece of wire into the hole about 2 inches. Another possibilty is a dirty flame rod. You can clean it with some steelwool. Let me know what you find if this doesn't help.
Sep 21, 2010 | Heating & Cooling
I have a toyo laser 56 stove. It is starting to make a moaning noise. what shoud i do?
Pilot,
Tom
Dec 16, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Tubearz,
Good luck,
Tom
Just an Idea...
Oct 07, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo 55, igniter gets hardened build-up
Gartyl,
Your Laser 55 burner mat has erroded away. The fuel is pooling someplace in the burner rather than spreading smoothly over the bottom. The stuff on the igniter may be hardened carbon from a poor flame. Bottom line is some burner work. A new mat, ring and cleaning the burner air holes is in order. Don't be surprised if the heat chamber is cracked beyond repair when you get it off. NOW for the bad news. The Laser 55 and 72 are older heaters. You will find just about all the electrical parts are going to be hard to find. They are no longer being made. Your 55 will be able to use the newer 56 blower, mat and burner ring. You will also be able to use the heat element off a 56 as well. If there is a problem with the fuel pump causing your poor flame you will be out of luck.
Good luck,
Tom Hawkins
hawkins111@gci.net
Mar 02, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
TOYO LASER 56
Here is a link to the owner's manual... look it over to see what may have come unhooked. If you can't solve it you may be able to contact the business for this web site...
http://www.rural-energy.com/publications/catalog/document/270
Sep 03, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo laser 56
Hi sammysamual,
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
EE2 code for toyo 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? The firing process is the burner button blinks green for 7-9 minutes, then it clicks up to the medium, yellow light which starts flashing. That is when the fuel pump starts pumping. If you hear a fairly audible tic tic, or thump thump coming from the fuel pump then that is your indication that the fuel pump is starving for fuel. You either have a fuel line restriction, too little fuel, a clogged filter, a clogged sump screen, or rarely, a failing fuel pump. Usually, it is a fuel line restriction.
If you hear no tic tic or thump thump and it just goes off on EE2 then the problem is in the burn chamber. You may have a carbon chain in the chamber causing the flame sensor to temporarily short out. You can clean the flame sensor, fuel nozzle, and igniter to resolve this problem until you can get your Toyo tuned up.
Clicking noises
check to make sure the wires going to the main fan are not hitting the blades.
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
27 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
