Question about Husqvarna Chain Saw 20" Bar
Petrol leak exhaust
Hi while trying to start my husky saw petrol comes out of the exhaust hope you can help
dave
  • 181 Answers
The unit is flooded...pull the spark plug and turn the unit over a few times to help dry it out.problem is that the crank case is also full of fuel.you can turn the unit upside down for a day to help the fuel out.install new spark plug,don't choke it,pull the trigger to full throttle pull the recoil ten times this will pull the fuel up to top of cylinder.remove spark plug pull a couple times and reinstall the spark plug.start the unit. if the unit floods again you have carb troubles.the needle is stuck open letting in too much fuel and it needs to be replaced.let me know if this helped.
Posted on Mar 12, 2009
395XP chainsaw
The 395 has an electronic ignition, as this unit works off speed of rotation you need to make sure you are cranking the engine fast enough to check for a spark, to eliminate the switch and wire, dissconnect the wire from the unit itself, now try for a spark, if still no spark with a new plug, you will have to replace the unit
May 08, 2012 | Husqvarna 395xp Gas Petrol Chain Saw Husky...
Wont start replaced sparkplug and does turn
Just chenk that it is mechanically sound, remove the muffler and check the condition of the piston skirt through the open exhaust port, any signs of scuffing and it will need to come apart to assess the damage.
Sep 30, 2011 | Husky Husqvarna Chain Saw 240E w 16in bar
Stihl st410 , after first pull it fires then turn...
Remove the carburetor and open the lower chamber--check the condition of the diaphragm and fuel metering valve--either of which can cause flooding. The diaphragm should be flexible and not cracked or have holes in it. The metering valve point should be in good condition. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. This information applies to nearly all saws even with other brands of carburetor. When you have the carburetor installed, remove the spark plug, open the throttle fully, choke and ignition switch off, then pull the engine through to expel the excess fuel from the engine. Reinstall the plug and attempt to start normally. Hope this helps!
May 17, 2010 | Garden
Petrol leaking when turned up side down,Ryobi Chainsaw
Upside down is not a usual sawing position--only upright, or turned to the left or right side is recommended. If you need to undercut something, keep the saw upright and cut with top side of the chain/bar.This can lead to kick-back if the tip comes free of the log/branch, so you need to control the saw carefully. That's also why there is a chain brake on all newer saws. The leaking may be occurring where the fuel lines pass through the wall of the fuel tank. Hope this helps!
May 04, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
When fueling with saw on side, fuel runs out the clear plastic hose that pushes into top of fuel tank
I suspect that this is a replacement fuel line. Husky uses rubber lines. Does the leak occur at the tank interface or does the line just hang free? If free, the end probably should go to the output side of the primer bulb. Replace this line with the correct sized rubber line. Most service shops carry various sized lines for nearly every saw. Hope this helps!
Apr 25, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain will not stay on
Hi Dave:
If you hold the bar nose up when adjusting and tightening the bar, then I think your saw is like detail A here (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HIUS/HIUS2008/HIUS2008_506955901.pdf
Configure it like detail B and the problem is solved. I did a quick search for item 16 (<$25) and available. You also need item 14 (2 each, $1±), and a scrench ($10± at a local saw store after you get the bar nuts).
If the saw listed is not yours, you can find yours here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 11, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hard to start.
My Husky 359 workshop manual says on Appendix A (USA) says "H" 3/4 turn CCW from lightly seated. "L" 1.5 turns CCW from lightly seated.
Page 36 (every other nation on earth) 1 turn CCW from lightly seated for both the "H & L" needles.
There is no recommended initial "T" setting. (from manual) "The idling speed is correctly set when the engine runs smoothly in all positions and there is a clear margin to the speed at which the chain starts to move". I wager your manual would be similar.
These are initial settings and the saw needs to be adjusted for performance. Start with a clean air filter and a fresh fuel mix @ 50:1 per Husky (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil).
This explains performance carburetor adjustment better than I can:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I hope you found this post helpful.
Lou
Jan 17, 2010 | Husqvarna Chain Saw 20" Bar
I have a powercraft chainsaw, do you know the petrol / oil ratio ?
Hi, Most chainsaws use three mixes, which are 32:1, 40:1 or 50:1. Most are labeled somewhere on the saw. If you are unsure, use the 40:1 and watch the smoke, too much smoke use less mix, but don't run with too little, it is supposed to smoke some. If you see any oil coming from the exhaust it is too much and can't burn it all. Good Luck, hope this Fixsya!
Mar 05, 2009 | Garden
Husky 61 leaks chain oil? Gasket on tank???
HI. TO FIX WHAT YOU ARE TALKING ABOUT, YOU HAVE TO STRIP THE SAW AND SPLIT IT IN HALF. NOW I HAD THAT PROBLEM ONE TIME AND I FOUND WHERE THE LEAK WAS CLEANED IT VERY GOOD AND PUT SOME JB WELD ON IT AND AS FAR AS I KNOW THE SAW IS STILL GOING. GOOD LUCK. JIMBO
Feb 27, 2009 | Garden
Leaking petrol
Hi bob
Below the carb there are towards the cilinder:a gasket,a plastik suport and another gasket.Check the gaskets from there.Also the 2 bolts of the carb should to be tightened.
cheers savumihai71
Dec 13, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
165 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
