Question about Pool & Spa
Sta rite error code cr8 - Pool & Spa
SOURCE: Sta-Rite SR400 heater displays error E01 and doesn't fire.
Resolved - the thermister was bad.
Posted on Jan 02, 2009
  • 83 Answers
SOURCE: sta-rite gas heater won't ignite
I am not sure if either of these issues have been solved, but with the AGS light on, you will need to check the flow of water first. If it is below what is needed for the heater, this will light up. If the water flow is fine, then check the water temp on the display panel. If it is readin higher than that of the ACTUAL pool water temp, you need to replace the Thermister.
If the water temp displayed is about that of the pool water, then the Automatic Gas Shutoff will be the next thing to check and replace.
You can tell IF a Sta-Rite heater has been converted by the model number. The Convesion Kit is supposed to come with a sticker stating that the heater has been converted, but there are two options for the kit and the one without the sticker is cheaper.
If you take off the top two halves of the heater, on the Junction Box there should be a Tri-fold card there. Unfold it, if the model number ends with NA it is a Natural Gas Heater, LP would be Propane.
Posted on Jul 10, 2009
  • 83 Answers
SOURCE: Sta-rite heater error code 126
The 126 is not an error code, but it maybe the temp of the water that the heater is reading. If the heater thinks the water is 126 degrees, it will not start at all.
If the heater is reading the wrong water temp, the problem is the Thermister, which is the sensor that is suppose to read the water temp. You will need to replace this sensor in order to correct the problem with the heater. It is really easy to do!
If you have a manual for the heater, if you go to the Replacement Parts Listing for the Electrical System, page 53 in the online version, the Thermistor is Item #9. It goes into the left side of the manifold in the to place, between the first two manifold bolts.
  • 83 Answers
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
  • 128 Answers
SOURCE: Sta-Rite Problem; Error codes R8, Won't stay on.
Its the top membrane where the control buttons are. The circuit board plugs in to it.
Posted on Aug 23, 2009
How to fix error code 6 on a sta-rite pool heater?
Try replacing the Temp sensor. You can not just jump it out, it needs to be repaced.
May 28, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
ERROR CODE E71
What is this error code? do you have any legend? this has no specific error codes as listed.
May 13, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
So how do I fix this problem "sta rite 400na gives error code 05 after about 30 seconds?"
if it starts check your stack sensor its the one the exaust ----- And if it dont start change your ignition plug
Jun 19, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Shows r 5 code when power is turned on. sta-rite
The R5 is a sequence code in the boot up sequence where your error is occuring. There is nothing in the users manual for these pool heaters that explains this error. Your best bet, unfortunately, is going to be to call Sta Rite. Here is their customer service number: 1-800-831-7133
May 08, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Aug 21, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta rite 400na gives error code 05 after about 30 seconds
Jun 14, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
