Question about Kitchen Appliances - Others
Ice machine stuck on clean
Clean stays on
    Novelist:
    Champion:
  • 373 Answers
OK check the off/ clean/ ice switch check with a volt meter one lead to ground and check the clean terminal with switch in ice mode if you are getting 115 volts to this terminal then replace the switch also make sure the purge switch is not sending power through it unless you are holding it down these are the only thing that will keep it in a clean mode.
Posted on Jul 08, 2014
Ice machine stays in harvest too long what's the problem
when in ice realese mode then the former plate heats for a few seconds the the ice will fall off easily i think if it stays too long in release its not detecting the heating cycle as start or finished or some end stop is wrong or the micro switch is intermittent so when it begins to release the switch is making the cycle short in time of event so ... it gets stuck check the usually three micro switches by replacement and all connections and give it a good clean also check the sensors {easy with some ice and water and a meter set to ohms}
Jan 02, 2015 | Kitchen Appliances - Others
I have a Scotsman SCN60 nugget icemaker and when I add cleaning solution to reservoir it just stays there
Hi, Are you using Scotsman ice machine cleaner? and are you using the right amount?
1. Open the door and turn the ice machine control knob to off.
2. Scoop out all the ice, discard it.
3. Pour 4 ounces of Scotsman ice machine cleaner into the ice machine reservoir.
4. Turn the ice machine control to on.
5. Allow the machine to operate for about 2 to 3 hours.
6. Pour hot water into the bin to melt the ice that has formed. That ice will likely be white and frosty looking.
7. Clean the bin liner of mineral scale by mixing some ice machine cleaner and hot water, and using that solution to scrub the scale off the liner.
8. Rinse the liner with hot water.
9. Sanitize the bin liner.
Now a dirty evaporator plate will not stop it from making ice it will cause it to hang up on the plate during harvest cycle if machine is not making ice good then there is something else wrong but when you clean the machine also make sure you clean the condenser coil and fan if this is dirty this will cause it to slow down on production of ice.
Dec 19, 2013 | Scotsman DCE33PA1BC 15in Built-in...
Hoshizaki water dont stop runing
float switch is stuck in the "down" position. The unit goes thru a fill cycle and after 1 minute, the board "Looks" at the float swith to "see" if the sump is full. If float is stuck down, it tells the board that the unit does not have enough water and stays in the fill cycle. The compressor will not come on as long as the machine "thinks" there is not enough water. let me know if I can help further
Aug 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
GE Monogram ZDIS15 has ice (sometimes) getting stuck on freezing plate. It gets hot & tries to release, but only partially (sometimes works fine). I have cleaned with solution, run the cleaning cycle...
It is time to run a ice machine cleaner through the unit, instruction should be on the door. When you get a build up is causes your ice to bind to the evaporator plate and cause this problem. Most ice machines require cleaning every 6 month to prevent this. Use nickel safe cleaner only, and most of the time this will correct the ice binding on that evaporator plate.
I hope this helps
Aug 11, 2011 | GE Monogram ZDI15C Automatic Icemaker
I have a Manitowoc s-450 with a AuCS-SI installed and it is set to not clean at this time. The machine is stuck in cleaning mode and is partially refrigerating. I disconnected the AuCS and it works fine....
When a Manitowoc goes into clean mode,It stays in clean mode until it finishes.If you turn it off and then on again,it just keeps cleaning.Let it run in cleaning mode until it finishes
Aug 24, 2010 | Manitowoc 450 Lb Ice Cube Machine Self...
Hoshizaki KM-900MAH Ice Maker it sounds like it is making ice and is freezing it but its not dropping ice any solutions?
when the machine first starts, it begins it's cycle in the harvest mode. If the float switch is stuck, it stays in the fill/ harvest mode. Compressor runs and water circulates but no ice is being made. I'd start looking there. Turn the machine on, let it run for about 3 minutes, they very lightly tap the float switch. If it starts making ice, bingo, theres your problem. Let me know if I can be of any more help.
May 12, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Apr 15, 2010 | Scotsman Cooled Modular Contour Cuber Air...
My iceomatic ice machine is not producing ice. There is ice frozen to the grate and water is not running
Could be a bad water solenoid. Could also be because it needs to be cleaned. If there is ice stuck to the evaporator, the hot gas bypass is not working. Try cleaning the unit first.
Nov 17, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
The ice has a bad taste to it.Cleaned all the parts and cleaned out the freezer. But the ice maker has a bad smell and the ice taste horrible.
Its possibly because of damp air cant dump out by the device as quickly as should be. It stays there longer than normally do and stuck on the foods etc. At no-frost devices there are a heater to keep machine working in normal way. If this heater is faulty or not working as it was before, this could be the reason.
You may experience bad cooling performance in the future (due to the clogged air ducts/passages by forming ice).
Jul 08, 2009 | Frigidaire FRS26R4A Side by Side...
Scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
Jul 17, 2008 | Scotsman Ice Maker 600LB CM3 30inW...
Kitchen Appliances - Others Logo
46 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
