Question about Northern Industrial 2 Hp Twin Tank Electric Air Compressor
My compressor starts up and reaches the desired pressure, but when I have used it for a short time and the pressure drops, it does not kick back on automatically. It bogs down and trips the circuit breaker on the unit. I have to hit the reset button and release pressure from the valve at the top of the cylinder. what causes this and how is it fixed?
    Scholar:
  • 89 Answers
YOUR COMPRESSOR MUST UNLOAD WHEN IT SHUTS OFF SO IT DOESNT START UNDER A LOAD THE NEXT TIME. MOST SMALL COMPRESSORS UNLOAD WITH A VALVE ON THE SIDE OF THE PRESSURE SWITCH.REPAIR VALVE OR REPLACE THE PRESSURE SWITCH (KNOW PSI OR TAKE SWITCH WITH YOU).YOUR COMPRESSOR IS STARTING WITH AIR PRESSURE ON TOP OF THE PISTON. CHECK VALVE COULD BE BAD BUT IT SHOULD BE BLOWING AIR ALL THE TIME.
Posted on Mar 14, 2009
    Problem Solver:
  • 11 Answers
My first guess would be an electrical fault in the pressure sensor, but as your compressor only does this after it works for a while, the problem should be related to heating, so, I'm betting on a seizing cylinder or bearing. Try running your compressor with a very wet towel wrapped around the cylinder to see if the problem is indeed heat related.
Posted on Mar 11, 2009
I have a a old Gibralco compressor when i cut it on it starts fine when it reaches desired pressure it stops and restarts until i kicks the breaker what can i try
i suspect that the start/run capacitor is faulty or the centrifugal switch in the back of the motor is faulty
have an accredited electrician check the motor , capacitor and the pressure control switch
the air leak at the head is a faulty non return valve in the compressor line to the tank
available at good tool shops for around $60.00
Sep 07, 2015 | Air Tools & Compressors
Kobalt gravity spray gun and I have a little air that comes out constantly. Why is that and how do I stop it? Thanks
You must be using a "turbin" which is different and better than a compressor however a turbin runs all the time and air must escape from it unlike a compressor with an airtank the shuts off after the desired pressure is reached it shuts it self off then turns back on with tank pressure drops below what you have set it at- a turbin reaches the pressure you set the regulater at and maintains it constantly NEVER STOP THE AIR FROM PASSING THRU IT in fact a lot of times i do this to remove any dust i may have missed so evrything is working like it should on yr sprayrig..
perry tradesman
Oct 19, 2014 | Kobalt Large Gravity Feed HVLP Spray Gun...
When I start my Job boss air compressor model#cffr350b It builds pressure to set psi and stops. Then after using any air gun for a while the pressure drops and the motor kicks in and struggle and will pop...
Whats happening is the compressor is trying to start with pressure on the head/ compressor. The motor is not strong enough to over come the pressure so the motor tries to run ,may be hum a little and pops the breaker. When you bleed the pressure in the tank down the motor does not have to over come the pressure and starts up as it normally would. Now, your problem is the check valve between the tank and compressor. It needs to be replaced. It is allowing pressure in the tank back to the compressor. Thus the compressor tries to start and can't. Trace the line from the compressor to the tank. You should find the check valve screwed into the tank and the compressor discharge line screwed into the check valve. Remove the compressor discharge line,then remove the check valve. Assemble in reverse . also you can loosen the fitting at the compressor. if it blows air all the time it's the check valve for sure.
Aug 08, 2011 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Compressor comes on then stops wait a min comes on again and imediatly stops again
If you are using the air supply between when it stops and when it comes on again, then this might be normal. You havent mentioned what model/size compressor you have, but if is only a small 1-4 Gallon tank model, then these dont really hold a lot of air, and if you are using any air tool that uses a lot of air, you will be exhausting the tank supply VERY quickly, so the compressor fires up again to refill the tank.
If the compressor is only staying on for a split second after it fires up again, try plugging the compressor in directly to a wall outlet (ensuring the outlet is properly rated) and avoid using extension cords, which can leave the compressor with little power to overcome the tank pressure to kick over and refill. Compressors are best run directly connected to a main outlet, not via an extension cord.
There may also be a problem with the switching/regulating mechanism for the motor if it is jumping on and off in rapid succession. Check your regulator/tank pressure gauge. Take note of what pressure it kicks back on at, and what pressure it stops at. Many compressors will kick back in when the tank pressure drops to 80 PSI, and may stop when the pressure reaches 100-120 PSI.
I hope that helps!
Feb 13, 2011 | General Air Tools & Compressors
Compressor wont kick down at desired pressure
replace the pressure vale or try lubing it for wd-40 first otherwise the shaft has worn inside and is sticking.
Jan 19, 2010 | Hitachi EC2510E 5.5hp Gas Air Compressor
Adjusting the pressure on the 2340-E
most air compressors have a pressure switch on them.this is used to adjust the desired pressure you want to reach.the second adjustment is for setting the pressure for when you want it to cycle back on.lets say you want it to run at 100 PSI.one of your adjustment in this box will control this , when you are using the unit and the pressure starts to drop to lets say 90 PSI you can adjust the unit to cycle
Oct 29, 2009 | Ingersoll Rand - Rand Type - 30...
Keeps on cycling on and of when not in use?
I believe you have a faulty pressure switch. The black hose reports to the switch what the pressure is and either starts or stops the compressor through the switch. Air is bleeding out of the hose ...causing short cycling ... for some reason. Fix the leak - fix your problem
Thanks for using FixYa.com
positive comments always welcome
a
Oct 27, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Air compressor motor stalls under pressure
this sounds like a bad pressure switch.if the unit is not shutting off at the same pressure each time this would be the cause.2 if the pressure is not unloading the air pressure on the compressor side of the unit it will cause the unit to struggle when it starts a cycle because the piston is under a load .how this works is say the unit starts from 0 psi when it get to the desired pressure you have it set on the unit kicks off . the other adjustment most units have on them is what pressure to cycle back on.so when the unit reaches say 100 pounds ,it kicks off and bleeds the air off the compressor side so when it starts back up it wont start up with pressure on the piston.
Jun 18, 2009 | Air Tools & Compressors
MY COMPRESSOR ONLY PUMPS UP TO ABOUT 65 LBS. CAN IT BE ADJUSTED TO HIGHER POUNDAGE?
yes most air compressors have a pressure switch on them.this is used to adjust the desired pressure you want to reach.the second adjustment is for setting the pressure for when you want it to cycle back on.lets say you want it to run at 100 PSI.one of your adjustment in this box will control this , when you are using the unit and the pressure starts to drop to lets say 90 PSI you can adjust the unit to cycle back on.
Jun 16, 2009 | Air Tools & Compressors
Northern Industrial 2 Hp Twin Tank Electric Air Compressor Logo
305 people viewed this question
Top Northern Industrial Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Northern Industrial Air Tool and Compressor Expert? Answer questions, earn points and help others
