Question about HP A620 Photosmart Compact Photo Printer
Printer not recognizing the image from memory card
    New Friend:
  • 58 Answers
Check the file format, maybe the file is not supported by the device
Posted on Apr 23, 2013
2 Suggested Answers
SOURCE: Scanner will not scan to image only printer or memory card
If you are using Windows 7, check www.hp.com for an update on the appropriate driver download page - there is a know issue with the driver software that prevents scans from being saved anywhere.
Posted on Aug 01, 2010
I have hp photosmart 145. Green light is on,memory card is inserted,no pictures are shown.Please help. Thank you. Pamala Barber
Hi!
Maybe the printer cannot recognize that specific file extension, what extension does the images have?
Jun 17, 2016 | HP PhotoSmart 145 4 x 6 Photo Printer
Transfering images to computer/ failure
Check to make sure your images are on the card, and not stored in any local camera memory. If the computer does not recognize the SD card (if used) and asks to format it, then try another computer to see if it can read the card. Finally, if the camera uses a cable, make sure the computer recognizes the camera when plugged in. When the camera is recognized, you should be able to directly view and download images from the camera. Make sure you note where the images are stored on the computer.
Mar 16, 2015 | Computers & Internet
My kodak easyshare 500 printer is not recognizing when I put in a memory card. Is there a reset I can do?
the memory card could be to large for it to recognize. look in the instruction manual for the max size. or just try a smaller card
Apr 26, 2012 | Kodak EasyShare Photo Printer 500
Windows 7 will not recognize the camera. Canon website says there are no drivers for the camera.
images can be viewed using memory card only on Windows 7. This requires your computer to have a memory card reader that you can insert your Camera's memory card into. If your printer has a memory card reader, you could use that as well.
If you want to use the camera with a USB cable, you will need another computer with Windows XP installed as the Operating system, or you will need to purchase a newer camera that is compatible with Windows 7.
Apr 14, 2011 | Canon PowerShot S330 / IXUS 330 Digital...
PNY Optima SD HC Card cannot be read in HP Photosmart 8150 printer.
  1. Verify that the printer is turned off.
  2. Remove the Secure Digital memory card from the printer.
  3. Examine the Secure Digital memory card:
    • Is the lock switch in the unlock position?
    • Are there any visible discolorations or defects such as crack or nick in the card?
    • Are there any contacts missing from the end of the card?
    • Are there any deep scratches in the card contacts?
    • Is there any heat discoloration on the card? NOTE: If all of the above questions result in No , proceed to Step 4.
  4. Check if the HP Photosmart printer supports the file format. NOTE: In order to know which file formats are supported by the different HP Photosmart printers, please refer to the manual of your printer.
  5. (Saving the pictures on the PC, if possible) Insert the Secure Digital memory card in the camera (or another device) and format it following the proper instructions to perform it.
  6. Capture an image.
  7. Review the image. If the image is corrupted or an error such as Unsupported Image File is displayed, the Secure Digital memory card is suspected to be defective and should either be replaced or referred to the manufacturer for further troubleshooting.
  8. If the images are read properly, turn on the printer. Insert the Secure Digital memory card in the Secure Digital slot.
  9. If the printer display continues to show the Card Not Recognized error, try using another Secure Digital memory card, if one is available.
  10. If the printer is still unable to read a functional and compatible Secure Digital card, contact HP to obtain additional troubleshooting information.
Oct 05, 2010 | PNY 4GB Secure Digital High Capacity...
Canon CP760 will not recognize images. I loaded
hi,
you can try picasa-the free photo software by google to do all simple photo editing. after editing directly print the photo from the program(rather than transfering to sd card) as this will reduce chances of non-recognition by printer.
cheers
Jul 17, 2009 | Canon SELPHY CP760 PHOTO Thermal PRINTER
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
X 5470 Memory Card not being recognized by my computer
First restart your computer. Double check if your memory card is locked, this is the little switch thingy on the side of it, it should say lock somewhere near it, slide it to the part not marked lock. If this doesn't help go to your start bar, click control panel, go to printers and other hardware, click on the memory card you are trying to recognize. Then it should give you some options on what to do with it and one should be load to your standard Lexmark Imaging Studio. I hope this helps!
Nov 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
Memory card on Lexmark X5470 not being recognized by my computer
Karen,
Sounds like your card may have went bad. A good way to check this would be to use a different memory card. Hope that helps! Good luck!
Sincerely,
Jeremiah
Dec 28, 2017 | Lexmark X5470 All-In-One InkJet Printer
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Dec 30, 2007 | Canon PowerShot SD200 / IXUS 30 Digital...
HP A620 Photosmart Compact Photo Printer Logo
15 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
