Question about Garden
Hayter H1842 transmission drive belt - Garden
2 Suggested Answers
SOURCE: How can I refit the
I did it with a large screwdriver. Pressing the band with the flat end of the screwdriver pushed the drive band back under the drive wheel behind the gear mechanism at the rear of the mower.
When it was back under, manually rotating the blade made the band run free over the drive wheel
Posted on Sep 25, 2011
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Hayter 56 pro lawn mower will not drive with weight on roller I have replaced belt
Sounds like the belt is slipping
Is your new belt the right one or is it the same length as the old worn one.
You might try spraying the belt with a belt dressing and that may work if its the belt slipping.
Another thought is your belt tightener working properly.
Just throwing out ideas to check.
Nov 12, 2014 | Garden
Hayter lawnmower manual
whats wrong with it i might be able to help
Aug 25, 2014 | Garden
How do you replace a broken cord in a hayter lawn mower
hi there i got a hayter lawnmower i want to know how to change a self propelled cable
Apr 06, 2012 | Garden
I have a hayter 13/40 type 144s ride on lawnmower and i am looking for a diagram to repace the blade belts
http://www.hayter-lawnmower.com/products/homeowner/handbooks/download.html?file=%2Fdata%2Fmedia%2F625%2F111-1012%20(Rev%20A).pdf&name=13%2F30%20Heritage%20Ride-On%20-%206%20Speed%20-%20131E%20(1).pdf
Apr 23, 2011 | Garden
How can I refit the drive belt from blade shaft to driving wheel gearbox on a Hayter R48 recycling mower?
Sep 18, 2010 | Garden
Hi i have a hayter heretige 19/40 ride on mower it has lost all drive the belt is fine but it just wont move can you help ?
I have a Hayter 19/40 ride on mower it starts and run fine but when I take my foot off the brack it cuts out can you help.
Aug 31, 2010 | Garden
THE STARTER CABLE ON MY HAYTER 41 PETROL LAWNMOWER HAS JUST BROKEN. HOW DO I PLEASE REPLACE IT, OR DO I NEED TO TAKE TO A HAYTER SERVICE ENGINEER? BRIAN TAYLOR
hi,if you can remove starter housing and think you are up to replaceing cord then you can get replacement cord from any repair centre but may be as well to take starter along and they should do it for a nominal fee ,which is cheaper than if you damage it doing it yourself,it doesnt have to be a hayter dealer since the engine is a briggs and stratton ,hope this helps
Apr 07, 2009 | Garden
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
