Question about Dirt Devil BD20050 Quick-Flex 2-in-1 Hand Vacuum Cleaner, 12 Volt Rechargeable Battery,Charging Indicator,Built-in Crevice Tool,Swivel Nozzle,Cordless
Can not find charger plug in on dirt devin 2 in 1 power flex
  • Dirt Devil Master
  • 18,424 Answers
Go here for manual > http://dirtdevil.com/file/709/
Posted on Apr 18, 2013
How to remove flexible hose dirt ***** featherlight bagless
You have to unscrew the back and pull the hose out that way
Aug 11, 2014 | Dirt Devil Featherlite Bagless Vacuum...
We have a Dirt Devil Scorpion hand held 6.0 volt DC vacuum model BD10050 manufacturing code B10C. Is it best to leave it plugged in or not? It does not say AccuCharge anywhere on the body or on the...
If it is a NiCad or a NMh you should only charge it when it needs it. A lithium can remain on the charger. Your battery packor the bottom of the machine will have the marking of what kind of battery it is.
Jun 06, 2017 | Royal Dirt Devil BD10050 Scorpion...
Hi, I have a Dirt Devil Cone vacuum and my daughter's dog chewed through the charger cord. Unfortunately, she threw away the charger part. I am looking to replace the cord and/or charger plug if that is...
Information on your Dirt Devil Kone M0213BLU can be found here:
http://www.dirtdevil.com/products/details.aspx?id=M0213BLU#parts
A link is available to download the manual and to find replacement parts. If the part you require is not listed suggest you contact the company through their website:
https://www.dirtdevil.com/contact.aspx
Apr 11, 2011 | Dirt Devil KONE Hand Vacuum MO213BLU...
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
Light says its charging but it wont turn on
Well first of all you may check that the charger (adapter) is working or not, you may use a volt meter to check it out or use another charger to make sure....... further you may follow the step below -
1. Remove the battery pack from Vacuum.
2. Hold down the power button for five seconds.
3. Reinstall the battery to reset the system.
4. Plug the Charger directly into vacuum.
5. Charge the battery untill the power light is solid green again and keep the vacuum on the charger for an additional 72 hours (3 days). Important: Do NOT interrupt this charging cycle.
If further you have the same problem it means it's time to change the old battery with new one.
Good Luck!!
Thanks for using FixYa!!
Sep 18, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
Light goes on my kone but it won't work
Good Luck!!
May 19, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
I can't get the charging light to turn on.
I have the same problem, after our building had a electricity problem. The electricity spiked when the utility company came to fix a problem. Several adapters in our apartment seem to be affected. Like my Kone, my dirt devil detailer had the same problem: charging light didn't come on, and while it charges, it only gets up to weak power. I got a new charger/adapter and when I plugged it into the base, the charging light was working again.
Jun 24, 2008 | Dirt Devil KONE Hand Vacuum MO213BLU...
Dirt Devil BD20050 Quick-Flex 2-in-1 Hand Vacuum Cleaner, 12 Volt Rechargeable Battery,Charging Indicator,Built-in Crevice Tool,Swivel Nozzle,Cordless Logo
91 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
