Question about Health & Beauty
Will rolater ros-rl8bg fold up for transport - Health & Beauty
Error 061-321 xerox workcentre 5024 - Xerox Office Equipment & Supplies
061-321 ROS Motor Fail
BSD-ON: CH6.5
The number of rotation of the ROS Motor did not come within the standard range within the specified time (5 s) after the ROS Motor On.
Cause/Action
1. Turn the power OFF and ON.
2. Check whether the Drum Cartridge is installed.
3. Check the ROS Motor (Output Check [061-001]) for operation failure.
4. Check the LD +5VDC power supply of the LD PWB J140 pin-8.
5. If no problem is found, replace the following parts in sequence:
• ROS Assembly (PL 2.1)
• ESS/MCU PWB (PL 18.3)
http://turbobit.net/upqkewkg8xjt.html
Feb 18, 2017 | Xerox Office Equipment & Supplies
What is a ROS system Failure
ROS stands for Raster Optical Scanner which is the scanner head/lense. This will need some cleaning from time to time depending on how much it is used. consult the printer manual on how to clean it.
Aug 06, 2014 | Xerox Office Equipment & Supplies
How do you fold this chair for transport
I don't know about yours but on mine you just grab the edge of the seat in the middle and lift up. That folds it easily.
Mar 17, 2013 | Drive Infinity Wheelchair, 18" Seat,...
Ros failure minolta magicolor 3100
Never heard of Ros missing something?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 14, 2012 | Minolta Office Equipment & Supplies
What is a Folding Bicycle?
A folding bicycle is a bicycle that folds for convenient storage and portability. The perfect folding bike would be one that rides as well as a quality full-size bike, folds in seconds, weighs less than 10 kg (22 lb), and folds small enough to fit under a bus or train seat.
Dec 16, 2010 | Cycling
How do I close up the stroller for storage
If you look at the handle where the break is you should see two red buttons or round clips on either side. Press each side at the same time w/ your fingers and pull up while doing this. The stroller should begin to fold. Once it begins to fold you then need to make sure that the front wheels are straight in order for it to fold completely. Once folded you can then use the straps on each side to ensure it stays closed. This is not the easiest stroller to fold or transport but still a life saver when you have 4 children to haul around. I wouldnt trade it for the world.
Dec 14, 2009 | Foundations 40-NM-BO Quad Seats Stroller
Error 10 laser unit failure on phaser 7700GX
That requires the replacement of either the ROS ( laser) assembly or the MCU board. I have seen both cause that code and indicate the laser has failed.
ROS is the laser assembly.
MCU board may not be detecting the ROS.
It is possible the connector that runs from the ROS to the board is loose, you may want to disconnect and reconnect that.
If the ROS is bad, you also have to have a laptop to connect to the machine to align the colors. That is called the regicon adjustment.
Apr 24, 2008 | Office Equipment & Supplies
Health & Beauty Logo
225 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
