Question about Freezers
White powder on floor in front of upright freezer
2 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: water in the floor
there is a drain hose that comes out of the bottom of the cabinet into a drain pan underneath your freezer take a look and see if that got pulled loose during your move. if it is in place then you most likely have a plugged drain. this can be cleaned fromt he inside at the botom. reomve the bottom basket and the shelf right above it. you will see ice build up on the floor of the freezer and and behind the cover. just defrost the ice you will uncover the drain hole flush warm water thru the line till it runs clear. good luck peyton
Posted on Jan 30, 2009
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Blue liquid drains from bottom of freezer
you have refrigerant on the floor you need to A&E FACTORY SERVICE @ 1-800-862-9226.
now you can not do it yourself you need a trained technicians to do the work
Jan 16, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How do I remove the drain pan to clean it. My freezer is frost free frigidaire upright. The defrost timer went out and some of the food defrosted and drained into the pan and on the floor. There is some...
On older freezers/refrigerators the drip pan could easily be removed. On newer models its now part of the base frame and their is no way to remove it. Dam shame if ya ask me since it was recommended noraml to remove and clean drain pan every couple months, but hey ain't modern technology great hehehehe
Gene
Aug 01, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Where is the drain hose located on this model of freezer?
bottom front of the floor in the middle.open the door and look down at the bottom floor in the middle front of the floor panel. http://www.searspartsdirect.com/partsdirect/index.action go here and enter your model number and you'll see a picture of it.hope this helps.
Jul 10, 2011 | Woods Upright Freezer V1613RW3
Need to change the leveling on an already loaded freezer . Is the bottom front panel a way in?
It's HEAVY --BUT it has to be raised at the front somehow (understructure may bend if not careful)--then nut adjustment loosened & adjust.
Feb 07, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidare Model No. FFU1464DW2 is leaking water on ground floor, can you tell me where to find the drain pan and what is causing this? Many thanks.
Most likely it is leaking because the drain in the back of the freezer is clogged. The most likely source of excessive water drainage is a bad door seal which causes frost to build up.
Nov 19, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I do not have a manual so I don't know how to defrost it
Look for a white plastic plug in the floor of the freezer, about the size of a quarter. Remove that. Take the front grill off and feel underneath for a plastic hose (one end connects to the drain hole, the other end you can catch defrost water in using a shallow pan). Use a hair dryer to melt the frost (with the freezer unpluged)
May 31, 2009 | Frigidaire Freezers
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
