Question about Xerox WorkCentre 3315/DN MFC / All-In-One Monochrome Laser Printer
Workcentre 3315 low toner warning
Getting low toner message after half of toner cartridge has been used
  • 2072 Answers
SOURCE: Replace toner cartridge message still on after replacing
lets start with the easiest and work our way up.
1, If you haven't already, remove the replaced cartridges, MAKE SURE the doors that open when the cartridge are inserted are closed, use a cloth to cover the doors and shake the cartridges. Make sure there is no tape or seal on the openings. Re install those cartridges with the machine powered OFF, reinstall them with the power off, then power the machine back on forcing it to initialize and look at the cartridges fresh.
2. Clean the machine internally with a soft cloth, or if you have a very well filtered vacuum with hoses, vacuum the interior of the machine, carefully. Some ink may have spilled on some sensors.
Please, when you remove and shake the cartridges to be certain the small door is closed and you have them covered so you don;t make a mess.
3. If needed look for a dealer service provider in your area and place a call. Dealer service is much less expensive then Xerox direct.
Let me know if this helps.
You can also go to www.xerox.com and click on support and drivers, in the search box, enter phaser 780, then click on support data base and enter replace toner and follow the steps there.
Hope this works. And Cheer up, take care.
Posted on Feb 19, 2008
  • 2072 Answers
SOURCE: can you refill a toner
They make refill kits, but to be honest, that cartridge is not made to work well when refilled. The metering blade will rarely work through two cycles.
Posted on Jul 12, 2008
AlmostBob
  • 550 Answers
SOURCE: toner installation error
take it out and try again, there are often adhesive tabs protecting certain areas of cartridges, that need to be removed, and that are not obvious
Not a guarantee, just something to try
Posted on Sep 09, 2008
  • 2072 Answers
SOURCE: my xerox workcentre pe 220 machine have an error message on "low heat error"
You will have to replace the fuser.
Posted on Apr 19, 2009
  • 110 Answers
SOURCE: error message: cyan imaging unit is either missing or unseated
The problem is with the top cover assembly. It could be a few things. I would first try the toner sensor flags(the magnet may not be strong enough to read properly). Also replace the toner cartidge because it's magnet may also have gotten weak. Third, I would try the Toner sensor board.
I have had this problem with many printers and normally it is just the flags because of the weak magnets.
Posted on Sep 08, 2009
How to by pass the toner empty warning on xerox m20i so I can use the remaining toner?
You can try shaking the cartridge a bit from left to right. If this doesn't work, you will need to order a new toner.
Jun 13, 2014 | Xerox WorkCentre M20i All-In-One Laser...
What does check process unit mean
According to http://www.partsdrop.com/info.php?info_id=Pro645inf the error message is shown on the webpage, are you sure the toner cartridge is the correct one
Dec 09, 2011 | Xerox WorkCentre Pro 765 Laser Printer
How do you change the toner cartridge on the xerox workcentre pro 423?
You can always find your solution to a Xerox problem at the Xerox Knowledgebase. Here is the direct link to this solution with pictures! http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=467,E=0000000002703228701,K=8434,Sxi=4,Case=obj(862)
Solution : Replace the Drum / Toner (Dry Ink) Cartridge
CAUTION: Do not use warm water or cleaning solvents to remove Toner (Dry Ink) from your skin or clothing. This will set the Toner and make it difficult to remove. If any Toner gets on your skin or clothing, use a brush to remove the Toner, blow it off, or wash it off with cold water and mild soap. If not, launder your clothes with detergent and cold water. If the fabric label says to dry clean, inform a commercial dry cleaner that the spot is Toner so that they will not use a solvent that will set the stain.
NOTE: Make sure the Cartridge part number corresponds to the machine model. If an incorrect Cartridge is installed the message 'Check Drum / Toner (Dry Ink) Cartridge Message' will continue to appear on the machine display.
  1. While lifting the upper, right-hand cover release lever of the machine, pull the upper right hand cover towards the right until it stops.
  2. Open the Front Cover on the machine.
  3. Grasp the Cartridge by the handle on the front, and slide it toward you until the top handle is completely clear of the machine.
  4. Lift up on the top handle and slide the cartridge out of the machine.
  5. CAUTION: Do not shake the cartridge and this could cause the Toner to spill.
  6. Before you remove the new cartridge from the bag, shake it vigorously from side to side several times to loosen the contents.
  7. Holding the new cartridge by the top handle, begin sliding it into the machine as indicated in the picture above. Do not push on the handle on the front of the cartridge as the cartridge will jam.
  8. Hold the cartridge in place and pull the Toner seal tape until the cartridge is completely in place.
  9. Close the Front Cover.
  10. Close the upper right-hand cover.
  11. If necessary, press [C] on the Control Panel to clear any messages. The system will initiate a Copy Quality adjustment cycle after you press the [Start] button.
Mar 01, 2011 | Xerox WorkCentre Pro 423 Copier
I have Workcenter PRO 416 and display says change toner but after replacing toner,the same message comes up.
I had that happen before. It turns out the refilled toner cartridge I was using was the problem. When I bought the cartridge I thought I was getting a new one. They were refills. You may want to try another cartridge if you have one.
Good Luck
Nov 30, 2010 | Xerox WorkCentre Pro 416 All-In-One Laser...
I get a toner low message with the Lexmark X342n when the toner keeps working for a few more months???
Depending on how much you use the unit it could. If you are a casual user and do not use it everyday I would not see why it would not. I have had toner cartridges which give the low toner warning and they last for years. The other thing you can do to extend the use of the cartridge is to remove it periodically and rotate it end to end and side to side. This will redistribute the toner across the roller and allow you to print good copies. If you don't do this the toner gets trapped in some areas and you could be throwing out a cartridge with alot of copies left in it. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 13, 2010 | Lexmark X342n All-In-One Laser Printer
J3 error On Xerox WorkCentre Pro - 215
A J3 means the toner cartridge is not compatible. That is the what the J3 message means.
Make sure the correct cartridge has been installed. For example, a Pro16 Toner Cartridge looks very similar and will fit in the machine, but it will display a J3 fault. Install a known correct Toner Cartridge if you suspect the cartridge in the machine is the problem. If the wrong Toner Cartridge has been used, the correct cartridge needs to be ordered and installed in the machine
It is possible the chip on the back of the cartridge is bad. Have you tried reseating the cartridge? Maybe it is just loose.
Dec 19, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Xerox workcentre Xl2130f copier printer error j1
that is the message for low or out of toner. What you are doing by tapping it is just lostening the reemaining ink in the cartridge. If the cartridge is new, have it replaced where ever you purchased it because most likely its defective.
Oct 02, 2008 | Xerox WorkCentre XD120f Copier
Low toner/toner empty
Toner cartridges have more then just "toner ink" they also have developer and sometimes a chip that says how many times the cartridge has been used.
Also some refill places can be a bit dodgy so I know it might not seem like the best thing right now but try buying a real replacement cartridge and if that doesn't do it beg and plead to return it saying it was the wrong model.
If it does fix it then you might have a bad cartridge that either has the "chip" or the cartridge itself is simply worn out and in need of developer as well.
Apr 16, 2008 | Brother MFC-8440 All-In-One Laser Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Xerox WorkCentre 3315/DN MFC / All-In-One Monochrome Laser Printer Logo
22 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
