Question about Watches
Manual for Structure by Surface Watch 32518 - Watches
I need locate instruction for a surface watch
Try Googling (surface)(model)(manual) without parens.
Jun 06, 2017 | Watches
I am looking for an instruction manual for a Structure watch 33415 model. There's an extra button or knob. What is it there for?
Fuzzy picture, but there are usually 4 buttons on a Sports Chronograph.
main knob pulls out and adjusts time, date and month depending on how far pulled out and which was turned.
one button is chrono start and stop
one button is split time
one button resets the dials back to zero.
I can't find a manual online
Dec 09, 2015 | Watches
Anyone have a manual for structure watch model 32441
Try typng structure watches in google search, there should be a website for that watch, then type in model number. You should be able to get a manual in this way.
Jun 09, 2014 | Watches
Can you help me set my surface watch model 33009
Are you sure the number 33009 is correct?
Most Wenger watches have 5-digit numbers starting with 7.
There is a Swiss Military Manual here:
https://www.wengerna.com/stuff/contentmgr/files/6/540159dc9885eeee1a65eec748ed4597/pdf/swiss_military_watch_manual_2012.pdf
May 07, 2014 | Wenger Swiss Military Classic Field Watch...
How to open the back of Kenneth Cole KC3434 watch to change the battery?
BASIC WATCH BATTERY CHANGE
Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
Best regards.
Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
Battery replacement. can not get back cover on.
mcdevito75 here, First look for any for any notches or cut outs on the cover, there should be a cut out on the cover for the stem, at this point line up the cut out with the stem, place the watch on a sturdy surface, Table, counter top, make sure the watch is completely flat on this surface with the cystal (glass) faceing up, now place the palm of you hand on the crystal and with even pressure press down slowly and evenly, the back should snap on.
Jun 16, 2010 | Pulsar PXH225 Watch
I inserted a new GE super mini mouse into my laptop and I am unable to use the mouse. What do I need to do to make it work?
I lost the manual for my Surface men watch please let me know how I can get one. Pauline
Jan 23, 2010 | Watches
Surface Watch Model 31819 How do you turn the alarm off?
I have a Surface Watch. Not sure if it's the same model number, but the button set up is the same. Here's what I did:
Hold down the bottom right button. While you're holding it down, press the top right button. My bottom right button doesn't seem to always work, so it made it rather difficult to figure out what has going on.
Dec 03, 2009 | Watches
I can't stop hourly chime in my Timex Indiglo
1-Place watch on hard flat surface.
2-Hit repeatedly with large hammer.
If you should need further assistance just ask.
Jul 24, 2009 | Timex 27191 Wristwatch
SCRATCH ON BLUE BEZEL OF WATCH
If it a scratch on a brushed surface try one of these watch Brush pens
Here only a couple bucks
If it is on a polished surface
try a cape cod cloth here
both are indispensable watch collectors items.
Dec 30, 2008 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
