Why does this board keep losing the network card
SOURCE: I need to install a network card for my IBM MS-6188
have you tried with a different network card? if no try with a different card. if it does not recognise it go to control panel and to add new hardware. follow the on screen procedure and see if it will see it.
If problem still persists, try doing a clean copy of OS
SOURCE: The on board ethernet adapters were damaged so i
There shouldn't be any issues if the network connection worked with the integrated NIC. Maybe you just managed to purchase a defective replacement card. The other possibility is that you didn't disable the onboard network hardware in the computer BIOS settings. There may be some conflicts since the motherboard is trying to address both of them. Make sure the onboard NIC is disabled, and try another PCI card if you still have problems.
SOURCE: just installed W7 onto abit Ax8 motherboard and no
Download latest driver from abit website.
SOURCE: The on board LAN network is not work, System
1 - simple test: connect the pc to a switch using another piece of cable and look at the led on the switch corresponding to the cable - if it doesn't light up when you plug the cable in the pc then the onboard LAN is fried. Unrepairable, get a new PCI one.
2 - that board has a VIA KM 266 chipset that has only one channel of memory that can be either DDR266 or PC133 SDRAM.
