Question about Hayward Pool Products Hayward Power Flo LX Above Ground Pumps
We had a big storm with lots of rain come through last night. My pump is scheduled to come on at 4am and I forgot to remove trigger. When I went out to pump out to waste, the pump was running normally
Hayward Super Pump, model C48L2N134B1
  • 717 Answers
Is there a question here?
Rod
US Parts Center
Posted on Apr 19, 2013
  • 8404 Answers
SOURCE: My Hayward Super II Pool Pump isn't priming. The
I think your impeller may be stuck OR your start capacitor has failed. Your pump is going off on over load because it cannot turn or cannot start.
Thanks for your interest in FixYa.com
Posted on May 16, 2010
john224
  • 1378 Answers
SOURCE: new 1.5 hp super pump hayward, blows circuit when
Recheck your wire connection on the motor. You likely put both your line wires on the same terminal. If not, try finding a local warranty center for a repair or replacement... http://www.haywardnet.com/locator/
Posted on Jun 14, 2009
john224
  • 1378 Answers
SOURCE: hayward 1hp super pump stops working
Your motor has a thermal protection switch in it the reacts to an overheating condition. Once the motor cools enough it will turn back on. You may be able to have the motor rebuilt for about half the cost of new if it is not damaged to severely. Take it to a local electric motor repair shop for service. If it is damaged beyond repair, you can shop around for a new one. If you would like a quote, contact us at www.arrowpools.net with your pump model number and we can quote it.
Posted on Jul 12, 2009
SOURCE: Haywards Super Pump Tick tack sound
The bearings and brushes are going. It could run like that for up to 5 years...
Some people specialize in fixing these, not too many though. I would replace the motor instead of throwing good money after bad.
Posted on Sep 05, 2009
MOTORWIZJ
  • 1383 Answers
SOURCE: Clicking noise in new Hayward Super Pump
make sure the pump motor is set for 115 volts, it soumds like you have the motor set at the factory 230 v setting and are trying to run it on 115 v look on the motor label it will show you how to set the motor up for 115 v (if the breaker is wide 230 if its skinny like the ones that control your lights its 115v ..if you have ran it for awhile like this you may want to search your area for your local pool pump motor repair guy w/ free testing, because you may have damaged the start capacitor about 20.00 or less fix.if not this can come back to haunt you later,,jay
Posted on Dec 14, 2011
1999 volvo s70 problems What must I do to get the rain water drainage system working properly ?
Do you have a sunroof? Cars have drainage holes up there that often drain into the door jamb on the front doors and sometimes down the rear pillars and behind the trunk/boot lining and exit the car near the wheel wells. Often, the connection at the top to the pipe comes off at the top corner of the windscreen.
Others have the same problem. Sunroof drain mentioned and how to fix.
https://www.youtube.com/watch?v=NgIdq1ha0go
More info here
1999 volvo s70 problems rain water drainage...
Mar 21, 2017 | 1999 Volvo S70
Left in rain
put the dsi into a bag of uncooked whit rice and leave it there for a week then try again the rice will pull the moisture out
Oct 31, 2013 | Nintendo DS Video Game Consoles & Games
My pool won't run on backwash
A new Multivalve gasket (Or Cam) may be needed. you will need to disassemble the Multivalve.
Jul 23, 2012 | Hayward SAND FILTER, PRO SERIES
I owe a Kia Sorento 2005 and my back wiper won't shut off. We had a big rain storm last night and I used it and when I got home I shut it off. Today when I start my car it just keeps going and...
Hey Rk_
The switch may have gone bad.. or the module that controls the wiper... if the fuse went bad, it would not work.. REMOVE the fuse if you want it to stop...
Search from over 10 Million Auto Parts
Jul 03, 2017 | 2005 Kia Sorento
My pump and filter has been working perfectly, even thruout rain storms. Today, It is raining heavily in central NJ and The motor is rumming, but no flow from the return. As if a connection o is broken...
Try to prime the pump!!! Also, if you have a system that used diatomaceous earth, may need to clean and add??? Last resort after checking for flow problems, filter and prime is to open the pump and check the impeller.. Good luck...
Aug 14, 2011 | Hayward 1.5hp Power Matrix Above Ground...
GE Advantium Oven - LED lights went out.
if anything like my own it is the led blub thats blowen - major hasel to change out - get some one who knows these cookers/ovens...
Aug 07, 2009 | GE Monogram ZE2160SF Convection /...
Indicator lights saty on.
A belt wouldn't cause all those lights to come on, If you were driving through a lot of water like you stated, it might have shorted out the Body Control Module, would recommend taking to a repair shop or the dealer to have this repaired. Hope this helps
Jul 12, 2009 | 1999 Honda Accord
Lost signal from the satellite
Signal Fade And Loss ~ Important, especially during winter!
Keep in mind that satellite broadcasts occur directly from fixed satellites in space to users. UPLINKS TO that satellite can happen from almost anywhere in the world! This includes broadcasts from remote studios, satellite vans and trucks.
Even signals from the main providing studios are susceptible to weather conditons even tho they have huge, high-gain transmitting dishes!
Weather is a major factor for both the uplinks and downlinks! Storm clouds can block the signals anywhere in the signal path(s). Rain clouds do too ~ even if it's not raining yet. Water-laden clouds make some of the BEST signal attenuators.
So one may have a gorgeous day in San Diego (let's say), but storms back east could trash satellite reception at his location and potentially everywhere else!
As you know, weather conditions all over the US are changing constantly with many severe storms occurring this past week and during any winter. In fact this week there was total signal loss on several satellites and I suspect storms back east were a big factor.
So it could have just been issues of timing for you. The UPLINK had intermittent problems with signal paths semi-crippled by weather... YOUR weather was CLEAR, but your reception was far from problem free ~ only because of weather problems elsewhere.
If you see intermittent satellite reception do check out the weather... especially back east.
Hope this helps!
Feb 01, 2009 | DISH Network Televison & Video
Hayward Pool Products Hayward Power Flo LX Above Ground Pumps Logo
122 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
