Question about Philips DCP850/37
Replace battery for philips portable dvd player
SOURCE: Philips Portable DVD Player PET 730/98 Unlock Code Needed!
Philips PET730/05
Using remote control
Setup
Down arrow
Down arrow
Right arrow
212225 (you won't see anything!)
Left arrow
Down arrow
should now show region code box
Enter 0
Setup to save
Posted on Apr 09, 2009
  • 814 Answers
SOURCE: my portable dvd player has sound but no picture on the screen. pl
If you still have use of the on screen menu functions, you can try using the restore to factory setting option in the preferences section of the set-up menu. Press the setup button on the remote control and use the up and down arrows to find and highlight the preferences section, press ok to enter the sub-menu.In the sub-menu use the up and down arrows to find and highlight the default option. Press ok. This will reset the dvd player to the factory settings. If you do not have the use of the on screen menu, you can use the a/v outputs to a external monitor or television to perform the abouve procedure to try to restore the dvd player to normal operation. If all this fails you can call Phillips customer support at this telephone number. 1-888-744-5477 They will be able to help you, either solve your problem or get the dvd player serviced.I hope this information helps you with your problem.
Posted on May 31, 2009
  • 814 Answers
SOURCE: dvd player will not reconize a dvd when trying to play
Try cleaning the dvd compartment of all dust and debris with a can of compressed air. Check and make sure all the dust and debris is cleared of the laser transport and lens. Use cotton swabs and small amount of isopropyl alcohol to clean off the laser lens and tracks and gears of the transport . Use a cotton swab with a small amount of alcohol on the tip to clean the laser lens. Rub the swab gently across the lens, until it appear bright and shines. Use the other side of the swab to remove any excess moisture from the lens. Use cotton swabs to clean the rails and gear of transport. Applie small amounts of alcohol to the tips to loosen caked on dust or dirt. Use compressed air again to clear the dust and debris from transport area. After the through cleaning. Try the player again, using a dvd to see if the operation returns to normal. If not, try resetting the dvd player to factory setting. You can do this using the on screen menu to go into the settings. Use the remote control and press the settings button. Use the up and down arrows to highlight the preferences section and press enter. Once in the sub-menu use the up and down arrows to highlight the default function and press enter. This will have reset the dvd player to the factory settings. Now try using a dvd to test the player to see if it operates normally. If it does not play normally, you may have a proplem with the spindel, check it to make sure its is making good contact with motor, if it appears loose, applie a drop of super glue to snug up the grip. After it dries completely. Test the player again with a dvd. If the unit still fails to operate normally, you may be having problems with either the drive motor or the power supply circuits. For these problems you need to contact a service center. They will have all the service information to troubleshoot these problems properly. You can call Phillips customer support at this telephone number 1-888-744-5477. They will be able to tell you how to get the dvd player tested and serviced. I hope this information helps you with your problem.
Posted on Jun 01, 2009
  • 303 Answers
SOURCE: have lost car adaptor & rechargeable battery pack for PET704
You can buy a new one by clicking on the hyperlink:
buy replacement DC CAR power Adapter for PHILIPS PET704 PORTABLE DVD PLAYER
Posted on Sep 06, 2009
SOURCE: my philips dcp850 portable dvd play battery won't
have you had this problem fixed?
Posted on Aug 09, 2010
Where are the batteries located
On the bottom side of the portable DVD player.Look for a square plate with a four Philip srcews.Take out those four philips screws there will be a Litium battery inside that square hole.
Jan 03, 2011 | Jwin JD-VD740 Portable DVD Player
How can I replace the battery?
Check the bottom of the the other side,there is a square plastic plate with a four small philip screws.Take out those four small philip screws there should be a square Litium battery behind that plastic plate.
Dec 15, 2010 | Amphion Mediaworks M-510 Portable DVD...
Lost powercord
Go to www.sears.com the parts dept have make and model ready!
Thank you for useing us!
Dec 13, 2008 | TruTech PVS12701 Portable DVD Player
Philips Portable DVD Player Battery will not charge Where can I get it repaired@
Actually its a lithium battery. All you have to do is open up the back, take the battery holder / battery out and take that to a store with you to have it replaced. :)
Nov 13, 2008 | Philips Televison & Video
Phillips Portable DVD player 8.5"
Unfortunatly the " Phillips Portable DVD player 8.5" does not have expandable batterys to buy...... but i do have a tip,to make your dvd player last a bit longer " turn the backlight off,to do this go to settings" this will help!
thanks,and have a nice day!
Sep 13, 2008 | Philips DCP855/37 Portable DVD Player
Philips DCP850/37 Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
