Question about Grilling
Kenmore model 415.16135110. I converted it to natural gas and there is no difference in the burner if it is turned to hi or low. In the high position it is low to begin with. I followed the directi
There is no difference when I move the dial to high or low. It is always low. What should I check in the conversion that I did?
  • 63 Answers
SOURCE: cal flame gas conversion
hi my name is mark, there are several possablitys why it can not be converted, one could be the orifice is pressed in manifold, another is it might require a different burners with air shutters and a regulater. it was problably designed for propane only, to save cost.
Posted on Mar 14, 2009
freetek
  • 5568 Answers
SOURCE: Want to convert from LP to Natural Gas
Typically, the only thing required is changing any and all jets since energy content and pressure are different. The only source for these is probably the manufacturer; check their website.
Posted on May 20, 2009
  • 512 Answers
SOURCE: Converting Weber from LP to Natural Gas
On the weber model you need to purchase the natural gas model. It will cost you alot more to buy all parts needed to convert. Weber doesnt want you to convert do to safety reasons. This is why they will only tell you you can't convert. Buy the right grill and save yourself a headache.
Posted on Jan 20, 2010
SOURCE: I have a Turbo Elite 3 burner barbecue. Want to
I have Turbo 3 burner which I bought from BBQ Galore about 12 years ago. It came with an extra set of 3 jets for natural gas. These have a larger hole than the propane ones. I don't know what else you would need to convert yours to run on natural gas, presumably your propane regulator will have to go. As I only use LPG you are welcome to my set of natural gas ones. Send me an email with your details and I will send them from here in Spain. Regards. Peter Durk pdurk@hotmail.com
Reply
Posted on Apr 06, 2011
  • 4736 Answers
SOURCE: I have a kenmore ellite bbq model 141.16691
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Posted on Aug 06, 2011
Testimonial: "I am taking your advise and leaving well enough alone!"
Burner comes on at 3.any lower goes out.6 inch yellow flamestarts on rite side under pressure.not burner rite of burner
Troubleshooting :: AZ Patio Heaters and Replacement Parts
azpatioheaters.com/pages.php?pageid=11
How do I replace starting striker switch on a tall patio heater? How do I clean ... Why is my burner flame low? Why does ... Why does my pilot light, but goes out when heateris turned on high or low? Why do I get a yellow flame and black smoke? ... 6. Can I convert my LP gas patio heater into a natural gas patio heater? NO.
Nov 17, 2015 | Heating & Cooling
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
Conversion of Kenmore Elite Gas Range 790.7523 from Natural gas to propane.
each burner has a natural gas jet or (orifice) as you pull them out, one atb a time. You should be able to color coordinate them at that point. the jets will be at the end of each gas line right before the burner. and each burner gets one. I haven't seen the model you are referring to. but the ones i have changed out in the past, usually the hole is the same size for all the burners no matter the size of the burners. I hope this helps. good luck with it!
Jun 17, 2015 | Kenmore Kitchen Ranges
New kenmore gas range 790.7433 converted to lp and oven flames are way too high and produce lots of soot...how fix?
Do the rangetop burners act OK, Brenda? It's just the oven that's causing a problem?
Go back to the oven burner, right where you installed the new orifice. That orifice should fit inside an air mixture tube, probably stainless steel, leading to the burner itself. Right where the orifice fits into it will be some means of adjusting the air mixture - a sliding window of some sort, whether flat or round. You'll need to loosen the screw holding it in place (DO NOT remove the screw, only loosen it) and turn it so the air opening is larger. Right now you're getting too "rich" a mixture, too much propane & not enough air. Before you close it all up, try the oven again - see if your adjustment worked correctly. If not, adjust it again - this is a trial-and-error process, and it's different for every different altitude and climate.
At some setting, you'll get a nice blue flame with very little orange in it. If you live in a very high humidity area, you'll have much more orange color than people who live where it's very dry, but the flame should at least be MOSTLY blue, and should never be sooty.
Aug 01, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
Upper & Lower Broiler Flame Adjustment
MY KENMORE OVEN BURNER FLAME IS TO HIGH AND IT WILL NOT TURN LOW
Jul 16, 2008 | Ovens
Kenmore 32099 Cooktop burners regulation
remove the burners and adjust the air ration with the slide at the bottom of the burner tube
Jul 25, 2007 | Kenmore 30 in.32099 / 32094 / 32092 Gas...
Grilling Logo
49 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
