Question about Acer TravelMate 240 Notebook
Powers up, get four beeps, then powers down - Acer TravelMate 240 Notebook
    New Friend:
    Problem Solver:
  • 6 Answers
System Timer Failure
But it matters what motherboard you have.
http://www.computerhope.com/beep.htm
This is the link I use to get started.
Posted on Apr 18, 2013
My kidde 7co model beeps four times then i beep then shuts off. any ideas
try this
http://www.computerhope.com/issues/ch000607.htm
Nov 29, 2016 | Computers & Internet
4 beeps when i power on my laptop
check memory, it is a system timer failure (if the beeps are short), usually its because of bad ram, but if u took it apart could be you just need to check how you inserted the RAM.
Nov 05, 2013 | AOpen Computers & Internet
Touch screen calibration xerox 7345
Switch on the power while simultaneously holding down the numerical keys 0, 1, and 3 on the Control Panel.
The Calibration Screen 1 will display
In numeric sequence (P1 to P9), touch the intersections of the vertical and horizontal lines with the stylus.
Apply the stylus to each of the four line intersections. A black square should appear at the point of contact, and a beep should sound.
If four beeps are heard, adjustment is OK.
If you don't hear four beeps, repeat the adjustment from step 1.
Switch the power off and then on.
Feb 16, 2012 | Xerox Office Equipment & Supplies
Four beeps pc will not bootup
Hi John Jones:
1 long, 3 short beep means >>> Bad video RAM or video card not present. You need to check your RAM. Remove RAM and insert again.
If beeps are of high frequency then CPU is overheated, check you CPU fan.
Hope it works for you.
Dec 25, 2011 | Dell Computers & Internet
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
At start up, before windows loads, a consistent series of annoying beeping occurs....
If they're occurring right as you turn the computer on, it's your Power On Self Test (aka POST) letting you know. Since I can't be more specific, here's a synopsis of POST beeps:
One single beep followed by three, four, or five beeps -- System-board problems, possibly with DMA, CMOS setup chip, timer, or system bus. The computer usually won't boot when this is the problem.
Two beeps -- The POST numeric code is displayed on the monitor, usually nothing to be concerned about, but you might google the code on another computer and see what you get.
Two beeps followed be three, four, or five beeps -- First 64K of RAM has errors. Solution is to replace RAM.
Three beeps followed by three, four, or five beeps -- Keyboard controller failed or video controller failed. Either you won't be able to see or type with this error.
Four beeps followed by three, four, or five beeps -- Problem with serial or parallel ports, system timer, or time of day. Check your BIOS settings (usually F2 at start up) to make sure everything is correct.
Continuous beeps - problem with power supply. Probably won't do much with this error. At the very best, your computer will boot and run very, very slowly.
Hope that helped.
Sep 01, 2009 | Compaq Computers & Internet
When powering up I get 2 short beeps and one long one.
The beep code is signifying either improperly seated/ bad ram or improperly seated/ bad video card. Since you replaced the RAM I would say it would be a bad video card. Replace & reboot. Hope this helps & please remember to rate my answer. Thanks.
Jan 22, 2009 | Toshiba Tecra S1 Notebook
Hp Pavilion XT963 four beep startup and nothing
Since iam not sure about the beep noise that u get....becos there are different pattern for it.
so iam pasting this link and let me knw the pattern plz..
or else it could be the power supply which is not placed in properly try unplug and placing it back again.
or let me knw the exact noise that u get is it a beep noise or clunking sound or very, quiet jet taking or Noisy fans.
Thank you.
Oct 01, 2008 | Computers & Internet
Acer TravelMate 240 Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
