Question about IBM ThinkPad T22 Notebook
No power.with ac adapter connected the laptop shows battery low .
With ac adapter connected the laptop(IBM T22), shows low battery and then switches off, isn't it supposed to work anyway through the ac adapter. I thought even with a dead battery, using the ac adapter the laptop would work anyway, but seems i'm wrong. any answers, thanks Tony.
  • tony_tc1 Apr 21, 2009
    Ok, my fault just found out that the adapter was dodgy, and the battery was fully discharged. thanks again anyway.
  • bajaman61 May 11, 2010
    You are correct. You should be able to power up the TP normally with no battery attached. First, check you power supply for any breakage and be sure that all contact points are clean and snugly fitting along the power supply line. Another likely possibility is the yellow internal connection into which the circular power supply connection plugs into at the back of the TP's base. Is that loose?
Is IBM Thinkpad T22 equipped with WIFI & what's the USB port vers
IBM Thinkpad T22 doesn't have Wi-Fi adapter installed. you need a USB Wi-Fi adpater in other to have Wireless connection.
You can go for D-Link, 3COM,belkin USB Wi-Fi adapter. Make sure the USB Wi-Fi adapter support the Operating System you installed.
Good Luck.
Jan 08, 2010 | IBM ThinkPad T22 2647 Notebook
Does not charge or turns on when plugged in to the power.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 23, 2009 | IBM ThinkPad T22 2647 Notebook
Can't power up. my IBM ThinkPad T22. I have the green light that indicates that it's charged up, however when I push the power button it just makes a flash and nothing happens.
If you only get a green light, try removing the battery first. If a laptop battery has gone bad, it will prevent a laptop from booting up.
Now, if removing the battery doesn't resolve your problem, check the laptop charger to make sure that the adapter has not malfunctioned.
If your fans are spinning, then the problem is probably the one listed below.
The transformer may not be converting the voltages properly.
Try these steps first. If it comes down to the internal transformer, then you have to contact IBM.
Aug 09, 2009 | IBM ThinkPad T22 2647 Notebook
Can barley see screen on t22 thinkpad
It might be that the power supply, battery, or backlight. Try pulling the battery out using just the power supply. If you have another power supply try that also.
Jun 25, 2009 | IBM ThinkPad T22 2647 Notebook
Getting hot underneth
Both batteries could be dead. But if you bought a new battery, it's unlikely. I don't know what green light you see, but if it's on the power adapter, it just means it's turned on--not that it is charging.
Two possibilities: Your power adapter is bad or the motherboard is bad. Because you say the computer works if plugged in, then you have ruled out the adapter.
You should be checking/cleaning the battery contacts and if all else fails, going for a new motherboard.
Jan 16, 2009 | IBM ThinkPad T22 2647 Notebook
IBM Thinkpad T22 Battery
pls first check your adapter may be problem with your adapter.
thank you
Sep 28, 2008 | IBM ThinkPad T22 2647 Notebook
IBM T30 - power issues
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Jul 11, 2008 | IBM ThinkPad T30 2366 Notebook
My T22 unable to start
Hi Yamato,
It is possible that the battery has been so depleted that it gobbles up all the power from the charger/adapter and leaves nothing for the laptop to use. Perhaps what you can do are:
1. try and charge the battery at least overnight with the laptop off;
2. use the adapter/charger only and remove the battery from the laptop.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 10, 2008 | IBM ThinkPad T22 2647 Notebook
IBM T22 Battery won't charge & is not detected
Take it to a very good technician who will open it up and check a dry joint in the charging system.  Sometimes if you donot attend to it quickly you may find your T22 refusing to power at all with the AC Adaptor.  Delicate soldering may solve your problem.  Power may not be getting to the charging circuit and the battery thus it is totaly discharged.
Oct 24, 2007 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T22 Notebook Logo
215 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
