Question about Insignia Kix MP3 Player
My volume down switch is not working??the system dropped from my hand.cn i gt an alternative part of it??
  • suman_billyj Mar 11, 2009
    u mean buy a new one??
    Genius:
  • 1,066 Answers
This would be cheaper to replace than fix
Posted on Mar 11, 2009
Samsung 5233 volume key jumper
my sumsung gt 5233 volume switch not working any alternate to increase or deacrease the volume
Jul 03, 2012 | Samsung Star GT-S5233 Cell Phone
Reset
If you want to apply a soft reset, i.e., thus keeping all your data and installed applications, press and hold the power button, until a context menu comes up, and tap 'Power off'. Wait for it to turn off, and press and hold the power button again, until you see the Motorola logo screen. It will come back to life restarted. An alternative way, useful in case your phone is stucked in some odd state, is to remove and re-insert the battery pack.
On the other hand, if you want to hard reset your phone, i.e. restore it to its factory defaults, thus loosing everything you have installed, as well as your personal data, if your phone is operational, go to 'Menu > Settings > Privacy > Factory data reset'. There is a checkbox to optionally clear of your SD card as well. Then, tap 'Reset phone'. On the other hand, if your phone is stuck (i.e. not operational), proceed as if you were soft resetting it, but, when it starts the process, i.e. as soon as you see the Motorola logo, Press and keep holding the volume down (-) key, until you see an exclamation mark. Then, press both the volume down (-) and up (+) keys. The Motorola boot menu screen will come up. Selection of an item is made through either the volume up or down keys, and selection is through the power button. Select 'Recovery -->', then '[Custom Recovery]' and 'wipe data/factory reset'. You will be prompted to select that action again, listed between a lot of 'No's. Afer the wipe is done, select 'reboot system now'.
Hope you are able to sort your problems out soon.
Anyway, please, let me know if Ican assist you any further.
Regards, Carlos
Sep 18, 2011 | Motorola Mobility Defy Cell Phone
How do i turn my keypad sound off on my corby pro without turning off my ringer
Go to settings-> phone profiles and tap on the [>>] icon next to the profile for which you want to make keypad silent (for eg:- normal). from the drop down menu at top right, select phone sounds. Scroll down till you see 'phone sound volume'. Reduce it to zero. Done!!
Apr 17, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
My chatmate can hear me but i can hear her
might be ur speaker is not intgrated with mic give it for service
Dec 22, 2009 | Yahoo Messenger
Mike not working
Hi Shirley, you do not give your computer details or OS but here is a typical audio set-up
Laptop x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access some of your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower drop-box display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Dec 06, 2009 | MSI Starcam 370i Webcam
Can not get audio working on hp2159m
Has sound been working in the past? If so - it's possibly a hardware issue but not always.I'll presume you're using Windows XP as the operating system.
Check these in the following order:
1. Check that windows volume is not muted. Depending on version of Windows, you may have a volume icon in the bottom right hand corner - it looks like a speaker - and if muted there will be a red circle over it.
2. Go to Windows Control Panel and Sound and Audio Devices settings.Check all volume are maximum.
3. Check that the right device is being used to output the sound by checking in Control Panel > Sound and Audio Devices > Audio tab. There are drop down lists. Check that Default Device is your soundcard (usually something like Soundblaster or similar.
4. It could be your Windows sound drivers. You need to go to HP website and look around for drivers.
5. Hope this helps and please report back how it goes...
Nov 20, 2009 | HP 2159M Monitor
Cannot get microphone controls to work, with either microsoft windows media sound, or realtek. How do i need to set up my audio drivers for a windows XP system using this motherboard?
Provided you have the correct drivers already installed for this motherboard, in Windows XP:
Control Panel > Sounds & Audio Devices > Voice Tab > Voice Recording > Drop-down box should have default device listed > Click Volume button > Adjust Microphone Slider
After completion, try Test Hardware button...
Nov 20, 2009 | ASUS P5N-E SLI Motherboard
How to know the volume of ram
If you can identify the memory inside the chassis, locate it and physically check. volume is ususally printed on it, or else it is displayed when the POST test is running, ie when you switch on the sytem before windows starts. Alternatively, after booting into windows, right click my computerand left click propeties in the drop down menu. however the ram volume displayed by windows is usually the volume less amount of ram used for display.
Nov 03, 2009 | Microsoft Windows XP Professional With...
Power will shut down after few minutes when volume reaches 12
If you check at the back of your hi-fi, you'll see a projection at the top where the cooler fan is located. The most likely reason is that your fan is not working (as required). In this system, the fan is turned on automatically at high volumes >=10, because then, the amplifier starts to get a temperature rise and without proper cooling the system might fault.
Try check and see if at these high volumes the fan is running, if not, then that's what needs to be fixed. Alternatively you can try running an external fan to see if it will produce the desired cooling effect.
Nov 25, 2008 | JVC DX-T9 System
Open Questions:
Insignia Kix MP3 Player Logo
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
