Question about Lenovo 3000 N200 Notebook
Windows xp will not load
When I switch on my LENOVO 3000 N200 A63 laptop, the screen becomes blue and it reloads. This continues to happen
  • Veli Kerim Celik
    Veli Kerim Celik May 11, 2010
    That exactly do you mean with blue??
    Like this?
  • 370 Answers
Ah, the "Blue Screen Of Death".
Solution as follows:
To resolve this problem, start your computer in Safe mode, remove the display adapter, rename the .inf files that are associated with the display adapter drivers, restart your computer in Normal mode, and then update your display adapter drivers. The following steps describe this procedure in more detail:
  1. Start Windows in Safe mode. To do so:
    1. Restart the computer, and then press F8 while the computer starts.
    2. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Safe Mode, and then press ENTER.
    3. Use the ARROW keys to select the operating system to start, and then press ENTER to start Windows XP in Safe mode.
  2. In the message that states that Windows is running in Safe mode, click Yes.
  3. Click Start, click Run, type msinfo32 in the Open box, and then click OK.
  4. Under System Summary, expand Components, and then click Display.
  5. In the right pane, note the information that corresponds to the INF File item, for example, Nv4.inf, Oem0.inf, or Atim128.inf.
  6. Quit the System Information utility.
  7. Click Start, right-click My Computer, and then click Properties.
  8. Click the Hardware tab, and then click Device Manager.
  9. Expand Display adapters, right-click the display adapter, and then click Uninstall.
  10. Click OK.
  11. Click Start, click Run, type cmd, and then click OK.
  12. In the Command Prompt window, type the following commands, and then press ENTER after each line: ren %systemroot%\inf\INF file name from Step 5.inf *inf.old
    ren %systemroot%\inf\INF file name from Step 5.pnf *pnf.old
  13. Close all open windows, and then restart the computer in the typical manner.
  14. Log on to Windows by using an account that has administrative privileges, and then wait for Windows to detect new hardware.
  15. When the Found New Hardware Wizard starts, click Cancel.
    If you receive a stop error after you remove the updated display drivers, restart the computer and use the Last Known Good Configuration option. To do this, restart the computer, and then press the F8 key while the computer starts. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Last Known Good Configuration, and then press ENTER.
    If you receive a "System Has Recovered from a Serious Error" message when Windows starts, restart the computer again. This error message does not recur.
  16. Obtain and install the latest drivers for your display adapter.For information about how to contact your computer manufacturer, visit the following Microsoft Web site:
Posted on Mar 11, 2009
Hi, I have a problem with a fan of my lenovo 3000 n200. Don't start.I have windows Xp and i have do a upgrade of bios. Thank Andrea
the fan problem is due to hardware problem. check the fan connection. it is not adviced to open a laptop because it void warrenty. so better to take to a service centre.
Aug 14, 2010 | Lenovo 3000 N200 Notebook
Can not install window xp
Your laptop probably has a SATA hard drive, windows XP only provides with PC's/laptops with a PATA hard drive.
You have to make up your mind what your really want to do.
1) Do you want a dual boot machine, working off XP and Win7?
Here's one web site:-
http://webtrickz.com/how-to-install-windows-xp-over-windows-7-in-a-dual-boot/
2) Do you want to replace Win7 with XP.
Here's a web site which covers that :-
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
May 04, 2010 | Lenovo 3000 N200 Notebook
Lenovo 3000 N200 system drivers
you can dawn load it from the internet
Oct 22, 2009 | Lenovo 3000 N200 Notebook
Lenovo 3000 N200 laptop not starting up, power light on
Keep pressed the power button of your laptop for about 30 seconds, the machine will power down.
--The above step may not be required as already so many days passed by.
Then plug it into the power adapter.
Switch the laptop on.
Boot in "safe mode" (F8 during boot).
This will fix any driver or some operating system issue during previous failed boot process.
Once it boots completely, do a normal shutdown and reboot your laptop in standard mode (no more F8 this time).
Now your laptop will be ready to use.
Sep 30, 2009 | Lenovo 3000 N200 Notebook
Startup Problem with Lenovo 3000 N200 with Vista
You would need to reinstall Vista together with the device drivers and programs to get a laptop functioning again.
You need to backup your data before you reinstall Vista but since you cannot boot up and get into Windows, you need to remove the hard drive and connect it to an USB hard drive adapter and then plug it into a working computer's USB port. This computer should see this hard drive as an external hard drive (provided the hard drive is OK). You can now see the various folders and files, copy your data files to a USB memory stick or burn them to a CD.
Insert the hard drive back into your laptop and then install Vista.
Jun 15, 2009 | Lenovo 3000 N200 PC Notebook
I need the webcam driver for Lenovo 3000 N200 0769 A63 webcam please help
try getting the driver from a website called softpedia or rapidshare
May 11, 2009 | Lenovo 3000 N200 Notebook
Computer keeps restarting
If your are able to access Windows the Screenshot it and paste it onto paint and tell use what it says.
Apr 02, 2009 | Lenovo 3000 N200 PC Notebook
Require Audio Driver for Lenovo 3000 N200 type 769 dual-core
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP audio driver for your model laptop,
www-307.ibm.com/pc/support/site.wss/MIGR-39956.html
Feb 22, 2009 | Lenovo 3000 N200 Notebook
BIOS Flash failed
if you still have the cd drivers from lennovo just put it on your cd rom and boot from it. bios flash will resotore 2 default
Jan 31, 2009 | Lenovo 3000 N200 Notebook
Sorry but your hard drive went bad.
Jan 13, 2009 | Lenovo 3000 N200 Notebook
Lenovo 3000 N200 Notebook Logo
159 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
