Question about Vision Fitness E1500 Simple Upright Exercise Bike
How to remove left pedal arm to remove outside plastic cover on vision exercise bike e1500
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: How to change belt on Vision E1500 upright bike and where to purchase new belt
see the video attached and proceed according. God bless you
http://www.youtube.com/watch?v=L1ViDZzCu2g
go to www.fitnessrepairparts.com and buy it
God bless you
Posted on Nov 19, 2012
The steel on the crank arm of my Monark 817e exercise bike broke, how do i remove it, it has no cover/nut/bolt/washer holding it to the axel
It's very difficult to find someone familiar with a particular model of a particular brand of exercise bike, but I pulled up some pics that seem to show that yours can have one of two types of crank. One is called a "one-piece" crank. Typically it is removed by unscrewing parts from the left side after removing the left pedal (left-hand/reverse threads). You may have to remove the housing to access and remove the parts. The other is a 3-piece cranks, and the arm will have a plastic cover at the axle. If you remove that dust cap you will see a bolt underneath. One has to remove that bolt and then use a specialized tool (crank extractor) to remove the crank arm. Check with a bike shop (take in the unit or take some good pics) for replacement.
Aug 05, 2016 | Monark Cycling
Petals turn freely with no resistance... is there a chain or belt?
if the pedals are direct to the wheel , there will be no chain
if the pedal arms are back from the wheel , it will be a chain which has probably broken or come off the cogs under the covers
The fix will be to remove the covers and see what has happened
Dec 31, 2015 | Schwinn 220 Recumbent Exercise Bike - 2012...
Recumbant bike makes aclunking sound whe pedaled
follow this steps and fix it. God bless you
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess grease
Loose Pedals
Kneel next to the left side of the elliptical's base. Use the Phillips screwdriver to tighten the two screws located in the center of the left pedal.
Use the Allen wrench to remove the bolt securing the left pedal arm to the pedal leg and body arm. Use the Phillips screwdriver to remove the screw securing the rear end of the pedal leg to the crank arm.
Pull the end of the pedal leg free of the crank arm. Wipe the crank arm clean, then apply a fresh coating of machine grease or silicone lubricant. Replace the end of the pedal leg back onto the crank arm and use the previously removed screw to secure it back into place.
Join the front end of the left pedal arm to the ends of the pedal leg and body arm. Use the previously removed bolt to connect the pieces together.
5
Move to the right side of the elliptical and repeat the above steps on the right pedal arm
Dec 09, 2013 | Exercise & Fitness
How do I remove the pedals on a 8500 life fitness recumbent bike
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Using a wrench, you remove the left pedal as you would loosen a normal, left hand threaded bolt. The right side is a reverse thread and would need to be loosened in the opposite direction.
Feb 20, 2013 | Life Fitness Nut Lock, Cranknut, Lifecycle...
How do I remove left pedal and replace with new one on Stamina recumbent exercise bike? Thank you!
there is probably a cap of some sort on the outside edge of the pedel you,ll have to remove, with a screw or bolt behind it. look for seam and then pry at it to remove it hope this helps
Jan 25, 2013 | Exercise & Fitness
What is a mini exercise bike?
A miniexercise bike is a bike with pedals and resistance parts only. It has no handlebarsor seat. You can use it while you sit on a regular chair and you can move thepedals with your hands for arm exercise.
Jul 30, 2012 | Exercise & Fitness
It is a seat-less exercise bike that can be used to exercise arms and legs. It's also known as a pedal exerciser. See www.miniexercisebikes.com for a list of bikes.
Vision Fitness E1500 Simple Upright Exercise Bike Logo
66 people viewed this question
Top Vision Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
rattack1511
Level 1 Expert
ray gallant
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
