Question about Radio Communications
I'm missing my key to turn off cobra alarm on my 1998 mx5. How do I get a replacement key? It's for the on off switch situated right on the alarm unit under the bonnet.
1998 R reg Mazda MX5 1.8S with Cobra 5802 remote control alarm and immobiliser system factory fitted. I have the remote fob but not the key for the barrel attached to the siren unit. How easy or difficult is it to replace and at what cost? Is it cheaper to get a locksmith? Cheers, Steve.
    Problem Solver:
  • 8 Answers
Go online to Cobra and ask a tech or see if they have a replacement
Posted on Apr 19, 2013
SOURCE: cobra 148gtl
tomcat 1 back ...i have found the fault no modulation on am/usb/lsb.tr -23 a bc458 transister .replaced this transister and wow modulation on all 3 modes thanks zeppfrog for telling me where to look .
Posted on Mar 01, 2007
SOURCE: how do you replace the meter light in a cobra 25?
You need to open the unit up ( remove the case/cover). Then remove the 4 screws holding the face plate on. Remove all the knobs ( they slip off) . remove any screws holding the meter on ( there may be none depending on which model you have ) . slide the meter out of the face plate and replace the meter with a new meter. Note: The meter light needs to be reistalled in the new meter. It simply slides out the side of the old meter and slide back in the new meter. Replace all the screws, and the jobs completed.
Good Luck and a good weekend to you.
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
  • 200 Answers
SOURCE: cobra 29 nw ltd won't transmit
Have you cracked the radio open yet?  check for loose connections etc.  get back to me if that doesnt yeild any results
Posted on Jan 22, 2009
  • 40 Answers
SOURCE: Replacing The Cobra 29 Nightwatch Illumination Panel
YOU CAN ORDER THAT PART FROM COBRA ELECTRONICS ON THE INTERNET YOU HAVE TO REMOVE THE FACEPLATE AND UN HOOK THE DRIVET INSIDE THE RADIO IT LOOKS LIKE A SMALL RIBBON CABLE THAT GOES TO THE FACEPLATE. SOME TIMES THE DRIVER ITSELF IS THE PROBLEM. MANY SHOPS JUST DO NOT WANT TO FIX THEM BUT I DO.
Posted on Mar 13, 2009
  • 773 Answers
SOURCE: Hi I have A Cobra 29 Chrome ED. that was plugged in
The protection diodes are D23 and D8. they need to be replaces with N14003 or bigger. they are near the back right of the radio near where the power comes in by the transformer.
changing the channel selector screen is just unsolder the old one, and solder in the new one. Getting to where to solder it is a pain. You have to take a lot apart.
Posted on Oct 10, 2009
Testimonial: "Thank you very much ! ! ! John"
How do i disarm cobra 7910 car alarm
Try getting in touch with the factory. You are not the only person who has encountered this problem.
Feb 07, 2015 | 1998 Ford Escort
Mazda mx5 will not start after flat battery battery now charged but soon as turn the ignition on the alarm goes off and will not start
You need to reset the alarm. If it's a Stock/original alarm, read the Owner's Manual or call a Mazda dealer. If it's not stock, you'll need to ID the alarm and look online for the instructions.
If your keyless remote fob has a Mazda label on it and is the ONLY one you have it's probably stock; if it's not a labeled Mazda, look for another name to find the alarm type.
GL,
Td
Oct 10, 2012 | Mazda Cars & Trucks
2006 buick alarm can not be shut off.....
After the key is put into what? The OEM alarm is armed and disarmed through the driver's door key cylinder. Insert the key into the key hole of the driver's door, turn to unlock, this disarms the factory alarm. Turn to lock, this arms the factory alarm. Now, if you have an aftermarket alarm this procedure does not apply.
Oct 07, 2012 | 1998-2002 Park Avenue Door Lock & Alarm...
How do you remove/disable a 1998 altima factory alarm?
You can't, it is an integral part of the electronic engine control system
Sep 27, 2012 | 1998 Nissan Altima
My 1995 chrystler LHS alarm system is not working right we recently replaced the battery in the remote but now we cannot get it to turn off the alarm what can we do?
You must have the dealer scan the control module to see what is triggering the alarm to stay on, a part is defective perhaps a door ajar switch or a defective key sensor.
Jun 15, 2012 | Cars & Trucks
I can't turn off the security alarm on my 1998 nissan pathfinder
I couldn't turn off the security alarm on my 1999 Pathfinder as I replaced the battery,
Solution: I read the solution here to disconnect the positive cable, open the driver's door, insert the key, then reconnected the positive cable, while honking, I turn the key to the left, to the right and to the left again while the door is still open. The honking stopped. Then I started the truck without a problem. Thank you for the hint.
Jun 12, 2012 | 1998 Nissan Pathfinder
1998 yamaha yzf r1 meta alarm
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Can disable meta alarm immobiliser
Faulty Meta 357T Alarm Immobiliser On My ZX6
1998 1999 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 03, 2012 | 1998 Yamaha YZF-R1
Pairing new alarm fob to cobra 777
Turn ignition key on and off around 5 times or till you here the alarm then hit the left and right button on fob till you here the alarm again then it is set. if you have 2 remotes you need to do them both at the same time.
Apr 07, 2009 | Vehicle Parts & Accessories
Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
Cobra car alarm
check if the switch in the bonet is damaged (sometimes working under the bonet you could damage the switch and miss it)installing a new battery should not affect the alarm
Sep 08, 2008 | 1997 BMW 318
Radio Communications Logo
146 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
