Question about Dishwashers
Beaumark dishwasher model #402010 how to clean drain
H?ow does the reset work
5 Suggested Answers
  • 48 Answers
SOURCE: beaumark dishwasher 400411
Assuming that it has gotten progressively slower over time, suggests a blockage of food, labels, etc.
-the sometimes it will drain...sometimes will not results each time you run it...the food becomes dislodged...then catches within the drain...note...this is a good thing...it just has to be cleaned out everynow and again...which most of us do not do enough:(
This is not a difficult fix...but can be really gross to do.
The first time doing this is sorta-hard...but once you do it once, see how simple it really is....you will only not wish to do it because you know the goop you will find :)
  1. open dishwasher door
  2. lift out bottom rack....sorta put your head right inside....try not to put too much weight on the door as you do it...yes this is awkward :)
  3. look at the bottom of the DW and there will be a circular hard plastic mesh/drain (lots of little holes, and perhaps even a larger catching reservoir)
  4. these holes and the reservoir have likely become clogged with food residue/labels, etc
  5. here is the gross part....scoop this out...BE CAREFUL.....especially if you have EVER broken a glass in the dishwasher....as the glass is mixed in with this goop!
  6. If you are feeling really adventurous...you can actually remove the circular basket to more thoroughly clean it..ie. wash it in hot water..scrub...etc...this is the best..
  7. to do this...the lower arm must be removed
  8. generally they are held in place by the 'cap'...turn counter-clockwise...spins off
  9. lift off arm....observe how it came off...set it down exactly the same way on the floor
  10. now the circular mesh is accessable...held down with clips (often the mesh is more flexible than the clips...proceed carefully..as it is plastic
  11. list it out
  12. clean thoroughly
  13. replace
  14. REPEAT PROCESS every so often.....if you do it enough you can stop at #5
hope this helps
Posted on Oct 08, 2008
6ylucy
  • 742 Answers
SOURCE: Beaumark Dishwasher 40210 won't turn on. I
check the troubleshooting section in your manual. If you don´t have it anymore, you could find one asking here
Posted on May 13, 2010
  • 10865 Answers
SOURCE: My Beaumark dishwasher is not
Hello gfa.... When the dishwasher won't drain completely it is usually because there is a partial blockage in the drain pump or in the drain line, or a kink in the drain line, or a partial blockage under the kitchen sink in the trap or even in the garbage disposal [if indeed there is a disposal].
Begin by checking the trap and making sure that it is freely flowing. If not, disassemble it and clean it out.
After that you will have to disassemble the drain line and thoroughly inspect it and finally remove the lower front panel on the dishwasher to access the low end of the dishwasher drain line and the dishwasher drain pump. Joe
Posted on Feb 18, 2011
ercupa190
  • 12223 Answers
SOURCE: Where can I get the owners manual for a Beaumark 18
try to go www .fitness.manualsonline.com or www. retrevo.com
or wwwmanualsfactory.com or www. pdfservicemanual.com
God bless you
Posted on Jul 11, 2012
God bless you
Jul 11, 2012 | Dishwashers
Beaumark bm-dw9702-ss dishwasher error code 004??
I had a error 004 on a Beaumark Model: BM-DW9702-WH Dishwasher which caused it not to run. The Manual stated it was To MUCH INLET WATER. I replaced the Inlet Valve with Part#: DW-53. The Dishwasher now runs great!
Oct 28, 2010 | Dishwashers
May 13, 2010 | Dishwashers
Won't drain, doesn't wash properly
Try running 2 cups ow washing soda through the machine to try and clear grease build up.
Make sure Salt level is filled (as this improves cleaning action)
If you cannot hear the pump working at the end of wash cycles it may need further investigation to free it or replace it.
If you can hear the pump working, remove outlet hose and clean the hose of all gunk and grease.
Feb 08, 2010 | Dishwashers
What is error 002 on Beaumark Dishwasher BM-DW 9702-SS
Error 2 = Longer Draining Time. The installation of the Drain Pipe is too high.
Apr 21, 2009 | Dishwashers
Beaumark jet dry dispenser
Hi puretonedoug,
I'm Harvey the Master Plumber.
Your question is: Beaumark Whisper Wash IV dishwasher jet dry dispenser does not appear to be working ( not using any jet dry) do they plug up or malfunction, if so how do you get it to repair or unplug?
The liquid jet dry dispencer only dispences a few drops in the last rinse. It is not uncommon for it to go a few months before needing refilling so it may not "appear" to be working. Are there spots on your glasses? That's the real test. If there are then just buy the jet dry that comes in a little basket that you hang from the top rack. Replace when it's empty and forget about the auto dispencer. If the glasses are clear then it's working and don't do anything..
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Dishwashers
Beaumark Whisperwash portable dishwasher has pile of macerated food scraps behind screen at bottom rear of machine. Dishes have "grit" stuck to them after cycle complete. Think the built-in...
That screen is held in place by two screws. Remove the screws, pull out the screen, clean it and put it back. You should perform this cleaning periodically to keep your dishwasher running perfectly.
Gina
Jul 11, 2008 | Dishwashers
Dishwasher
pump not working.
check wiring
Nov 28, 2007 | Heating & Cooling
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
Owen Barnes
