Question about Envision 19" Widescreen Flat Panel LCD Monitor
Seem to have locked the monitor in burn in mode
Monitor flashes through various colors on full screen - states it is "burn in". I cannot get it out of this mode to see computer information again.
    President:
  • 814 Answers
This problem is a failure of the control circuit of the logic section of the monitor. The control circuit has latched on this function due to failure of some component or the control itself.This problem requires you to return the unit for service at the dealer or take to service center. Hope this helps.
Posted on Apr 14, 2009
Padlock icon
Many monitors have an on-screen display lock (the padlock icon) that seems to get stuck.
Various suggestions in the links below - the one that seems to work most often is to hold the monitor's menu button down for 15-20 seconds to get the screen menu, then either try unlocking the OSD (On Screen Display) or do a factory reset on the monitor.
http://www.fixya.com/support/t448684-flashing_padlock_icon_in_middle_screen
http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Different monitors have slightly different menus, but if it's a Dell monitor you can find the manual below (under Display):
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&cs=19&l=en&s=dhs&~cat=3
Jul 07, 2014 | Dell E172FP 17" LCD Flat Panel Monitor
Watt is ODS mode
Somehow I have gotten my Dellicon1.png 1701FP Flat panel monitor into a state where it will not allow me to use any of the control buttons on the front of the monitor. Whenever I press any of the buttons (except power which works fine) the monitor brings up a padlock icon and nothing else happens.
This is not the "OSD Lock" function mentioned in the instructions because if it were I could get out of it by pressing the Menuicon1.png button and then minus. That should bring up the OSD Lock menu page, but it doesn't on my system, either buttons just brings up the Lock icon.
The controls worked fine when I got the monitor and it seems to have gotten into this mode when I had it face down (on a soft cloth) while changing monitor cablesicon1.png. It accidentally powered on and must have had some combination of buttons that caused it to get into this mode.
Any ideas how to get out of this mode so I can adjust it? Anyone know a way to reset the monitor (besides through the menu that I can't access)?
Apr 27, 2014 | Envision G22LWK 22" LCD Monitor
Dclcd monitor
Seems the screen resolution of your pc is high (higher than your monitor can support). You may lower the resoltion by connecting your pc to another monitor temporarily and changing settings then.
Nov 18, 2013 | Philips Computers & Internet
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
I have a Toshiba 51h83. Everything works fine except there is an issue where the colors are slightly lighter on both the left and right sides of the screen.
this is normal with rear projection tv's its from long usage when the tv isnt always in full screen mode. you can sometimes fix this by replacing the bulb/ or the color board for the projector. also you can replace the screen as it seems like it may also be do to image burn in if it wasnt always in full screen mode. (did this for my uncles Mitsubishi projection tv)
let me know if that helps!
Mar 16, 2011 | Toshiba 51H83 51" Rear Projection...
I downloaded clips from the memory card of my Canon Legria FS200 Camcorder. The clips looks fine in full color on the camera screen, but the colors are almost like "sepia" on my computer screen !
this is more likely to be an issue with your computers monitor settings rather than the video itself. try burning to disk and viewing on you TV you should find no problems
Nov 12, 2009 | Canon FS100 Flash Media Camcorder
Dell optiplex gx150 power button just flashes - help?
System seems to be in hibernate or standby mode and frozen in that state. Hold dosn power button for 5 seconds or until all signs of life shut down. Wait about 30 second and power up the system.
Jul 25, 2009 | Dell Optiplex GX270
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Dell AS501 flat screen monitor
The front panel switches seem to be the culprit.
If you are technically sound you maybe able to solve problem by opening monitor and clean front panel switches or replace them.
Samir.
Feb 28, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor Flashes Colors when system powered down
Reset factory settings. Push the selection button (second button from the left at the bottom of the monitor, next to the AUTO button), then go the the Factory Reset by pressing the minus button. Press the selection button again, and when it asks if you want to reset say YES by using the minus button. It's a quick fix!
Dec 20, 2007 | Dell E176FP 17" LCD Monitor
Envision 19" Widescreen Flat Panel LCD Monitor Logo
448 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
