Question about Philips 27PS55S 27" TV
27ps55s121 I have a Phillips 27ps55s121, it will turn on... stay on between 2-15 min. then shut off... whats going on???
I have one also, I'm looking for a manual out of boredom i guess, but, everywhere i look, i see all of my tv's probs. As far as the coax input, unless you have a solder kit, not much you can do other than get an adapter, use the a/v, or a vcr. the tv going off after a few mins, I solve by hitting the guide button on my dish receiver or what ever you have to stimulate the tube.... I know that doesn't sound right, but you know what I mean. It sort of warms it up. That also works for the sound. It really does work for me, its just basically, getting it to "wake up"
Posted on Nov 17, 2009
What's your problem?my television show black & white it has no color model no is 27PS55S121 philips, when i check the settings i set on auto, even the tuner is on auto eliud
if can not get with adjustment it could be a problem in the board, tried with re soldering cold soldered component joints at the video section.
Sep 26, 2012 | Philips 27PS55S 27" TV
Phillips 50P8341 will stay on about 15 mins then shuts off then the power button flashes twice, pauses then flashes twice again...
Seems like it is overheating. Try cooling it down by using a fan to blow air into it (temporary fix). Make sure the TV is well ventilated and heat can escape (permanent solution).
Jan 15, 2011 | Philips 50P8341 50" Rear Projection...
My tv 27PS55S121 philips star on and off
This is pretty common. Usually it's because of bad solder connections at a part called the vertical output integrated circuit. Resoldering the bad connections is often all it takes to fix the trouble. While it's a simple repair, unless you have experience doing electronic soldering you should have this done by a professional. It's possible to more damage. Take the set to a shop for an estimate (won't cost as much as a new TV).
Mar 18, 2010 | Philips 27PS55S 27" TV
My akai dlp tv turns itself off then it flashes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Feb 17, 2010 | Akai LCT3201TD 32 in. LCD Television
TV stays on for few mins and then turns off
IF its the lamp for Lcd. Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Part # is xl-2200 found it here: http://www.discount-merchant.com/SearchResults.asp?Search=XL2200+?Click=48173 God bless you!
Nov 17, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Wall furnace shuts off after about 10-20 mins
sounds like its not venting properly...it likely is shutting off on a "Spill switch" or "Vent safety switch"....check the vent/chimney first off.....also the pilot could be dirty..,..a lazy pilot tends to blow out easily....pilot should be blue and sharp,,,big enough to fully envelope the thermocouple
Oct 30, 2009 | Heating & Cooling
The tv shuts off after 15 to 20 mins. then 15 to 10 mins then 10 to 5 minutes. I tried to blow the dust out of the back but now it only comes on for a few seconds and shuts off again.
Im not sure what brand you are inquiring about. My Hitachi 50v715 DLP did the same thing and it turned out to be the Lamp was going out. I bought a new original hitachi lamp(phillips) and put it in and it works great. So if your lamp has not been changed out in a couple of years then its probably time. Hope this is helpful.
Oct 16, 2009 | Televison & Video
Wont stay on turns on for a second then i hear a
I have had the same problem with every Phillips with which I have had any experience. Service required, possible DOA.
Apr 17, 2009 | Philips Televison & Video
Philips Model #27PS55S121 TV (color)
Sorry it the picture tube it's going out. I'm surprise your color didn't fade first.
Apr 16, 2008 | Philips 27PS55S 27" TV
Monitor
try by uninstalling the video driver from safe mode and reinstall the driver.if the problem persist then your monitor needs servicing
Apr 02, 2008 | Gateway FPD2275W LCD Monitor
Philips 27PS55S 27" TV Logo
303 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
