Question about Microwave Ovens
Changing panasonic nn-s615wfx light bulb - Microwave Ovens
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic NN-H664 1200 Watts Microwave
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job.
It's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
To order Panasonic parts see http://www.pasc.panasonic.com/epartr ; To download a Panasonic manual see
http://service.us.panasonic.com/operman ; to find an authorized Panasonic servicer, see
http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 ; For FAQs, see http://service.us.panasonic.com/faq/faq.aspx
We appreciate your thoughtful rating of our answer.
Posted on Nov 18, 2007
freetek
  • 5568 Answers
SOURCE: Light out in Panasonic NN-S573.
If the inside of the unit does not have an access plate visible, you will have to unplug the unit, remove the 5 or so screws in the back along the edge, then lift the edge and pull the housing off of the unit.
You won't likely have one of these bulbs at home, they vary and are of the compact varity such as those used in sewing machines or at least a smaller globe than normal lighting bulbs.
Posted on Jun 10, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave shuts off after 2 seconds
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer (above) to get it fixed free.
Posted on Jan 03, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 23, 2009
  • 4090 Answers
SOURCE: Panasonic Microwave NN-S935BF turntable and light
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
No power to light or turntable
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Posted on Aug 16, 2009
How to replace light bulb in Panasonic microwave model NN-S446BA.
Here is the free online manual, but I did not see the light bulb change on my first look through: https://www.manualslib.com/manual/192230/Panasonic-Nn-S446ba.html?page=2#manual
There is a YouTube educational video that may help more: https://www.youtube.com/watch?v=sLidbz2LUtg
I hope this helps you out!
Apr 09, 2017 | Panasonic Microwave Ovens
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Magic chef overthecounter microwave external light doesn't work
This microwave's replacement countertop light is F60305H00AP. This can be obtained by going to www.panasonic.com/parts.
The instructions for replacing the bulb can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/NNSD277SR.PDF#page=28
Mar 02, 2014 | Panasonic NN-SD277WR - NN-SD277WR...
I want to change the light in my microwave. Panasonic nn-p704sw. I took apart the covr and foung the light attached to a plastic scockrt. I tried to unscrew but the bulb was tight. should i apply more...
Typically the bulb will unscrew from the socket. If you can remove the bulb and socket with the wire from the microwave (wire hanging from the microwave) you might be able to get more pressure on the bulb to turn it. Keep in mind that the bulb may have been in the oven for several years and there may be a build of grease on the treads of the bulb so it could be really stuck. Put a cloth towel around the bulb and wear gloves so you don't cut your hand if the bulb were to shatter.
May 02, 2010 | Panasonic NN-P794SF Microwave Oven
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Jun 10, 2008 | Panasonic NN-S753 Microwave Oven
Panasonic bulb nn a753
First, get the bulb part #F612E4W00AP or equal. Next, you should find a few screws around a plate in the unit through which the light shows through. Carefully remove them and the glass lens. When replacing the bulb, be sure it is in securely.
Dec 15, 2007 | Panasonic NN-T774SF Microwave Oven
Nov 17, 2007 | Panasonic NN-H664 Microwave Oven
Microwave Ovens Logo
82 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
