It won't show a start what shoud i do?
  • Computers & ... Master
  • 15,969 Answers
What is the make, model and operating system of the computer?
Posted on Apr 18, 2013
Headache
You might need a new starter what's happening is when the starter heats up it won't start up again until it cools off
May 30, 2013 | Vehicle Parts & Accessories
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Why did my task force 83691 compressor just stop working? Won't start.
Sounds like you blew the fuse. It takes a little 3 amp fuse. Also, this compressor only has a 33% duty cyle, meaning it shoud not be run more than 20 minutes per hour. Another thing, avoid using drop cords. If neccessary to use one, use a 12 guage cord no longer than 25 feet. Good luck!
Dec 16, 2012 | Computers & Internet
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Casio hr100tm won't print, shows E, won't feed paper. It calculates in On mode only.
mi sumadora, de repente se queda en E y no me deja seguir sumando cantidades que solucion tiene esto
Aug 22, 2012 | Casio HR-100TMPlus Calculator
2008 Saturn vue won't go out of park and shows it being in reverse and won't start.
Broken shift cable ?
If the neutral safety switch is on the transaxle and the cable is broken, the switch could still be in the reverse position.
Jul 05, 2012 | Cars & Trucks
My Cub Cadet 2130 has a Kohler Command 12.5 Hp engine. I have had a recent problem where if I shut the engine off after running for a half hour or so it won't restart. Today it died on it's own...
You most likely need to replace the ignition module. You should find it under the shoud next to the flywheel, just follow the spark plug wire.
Sep 18, 2011 | Garden
My x5 3.0i 2006 t won't start this morning but temperature, gas level clock were wrong so I turn the engine off and restart a couple times it won't start and I saw message trans. false safe...
no. I'd suggest to disconnect a battery for 15 mins, reconnect, wait for 5 mins and try to restart. If it doesn't help (sometimes there's a program block to prevent stealing equipment) call a dealer
Aug 04, 2017 | 2003 BMW 5 Series
Computers & Internet Logo
274 people viewed this question
David Payne
David Payne
