Question about Hardware & Accessories
Hoselock ac1 Mod.2705 valve does not close - Hardware & Accessories
  • varvacos
    varvacos Apr 20, 2013
    Hoselock 2705 valve, although mechanism is heard to work, valve does not close;it remains open.I assume the juction of mechanism and valve is broken . Can I fix it or I have to replace whole valve? Thanks in advance.
Dishwasher is backfilling when not in use and I just replaced inlet valve.
sounds like the water valve is letting by its electrically opened but mechanically closed if grit or a foreighn body enters the valve it will not seat properly you can turn off at mains when not in use till you get it replaced its not possible to repair as its a sealed unit.
Mar 03, 2017 | Whirlpool Dishwashers
On the crank gear an cam gear do the dots meet when its TDC an both values are open on a 17.5hp mtd OHC lawn mower ser#1a276b30280. Mod#13bn771g729.
both valves are never open at same time!! the 2 dots should meet up at tdcbth valves closed, valve clearances should be approx .006-.008 inch
Mar 03, 2015 | Mtd Garden
WHIRLPOOL DISHWASER MOD ADG8100 fault f6 is on what is that
There is a problem with intake water.
Could be:
- water tap closed
- water inlet hose blocked
- faulty water inlet valve
- faulty flow meter
Opening the water tap within the first 30sec. of the program cycle rasets the failure F6. After another 30sec. water inlet valve will close due to safety reasons.
Dado
Jan 10, 2015 | Whirlpool Washing Machines
Not water in the door
For a 1993 model, the problem is most likely a clogged inlet strainer on the solenoid operated valve on the back side of the access cardboard cover near the bottom of your refrigerator. If you take your model number to Searspartsdirect.com and you can order a new valve if the solenoid has finally stopped working.
Before to much troubleshooting, check the isolation valve where the water hose hooks up is open. It may be someone closed the isolation valve.
Hope this helps
Dec 15, 2014 | Refrigerators
Where is the egr mod located on a 1991 lexus es 250
When the throttle valve is positioned above port R, the EGR vacuum modulator will close the atmosphere
passage and open the EGR valve to increase the EGR gas, even if the exhaust pressure is insufficiently low. ON TOP OF PLENTIUM
Jul 31, 2013 | 1991 Toyota MR2
Unlock nokia 2705
Hi you can try Theunlockarena.com to get unlock code for your Nokia 2705 and get it unlocked..
Feb 14, 2012 | NokiaFree Unlock Codes Calculator
Comfort glow mod. cbt30pt lp gas valve closes off after ten seconds on
It sounds like you are loosing connection with your thermocouple to the gas valve.
Here are som einstructions on reseating the thermocouple.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
Oct 11, 2010 | Desa International CBP20T Wall Mounted...
Hot water continually runs into machine (kenmore 70 series type 111 mod # 110.26732500 ser# c823109162
The water valve has failed in the open position - or there is sediment blocking it from closing fully.
CLICK HERE to see a replacement water valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 02, 2010 | Kenmore Washing Machines
Bought a Hoselock Hose Reel today and cant figure
You need to purchase a Hoselock tap connector. There are two basic types, one has a thread that screws on to a theaded tap and the other type is a compession fitting that can be secured to most other taps.
The full range of connectors can be found on their website
http://www.hozelock.com/watering/hose-fittings/connect-to-tap.html
Mar 16, 2010 | Hozelock Garden
G213 -250 amp gas portable welder 1979 mod.
Hi, No compression means - The rings in the piston needs to be replaced, or the valves are stuck in the open or closed position. One or both of these is your problem.
If this doesn’t work for you, please write back. Thanks,
Nov 27, 2008 | Welding Tools
Hardware & Accessories Logo
20 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
