Question about Dell Computers & Internet
Cannot access c drive - Dell Computers & Internet
    New Friend:
    Problem Solver:
  • 6 Answers
Not much to go on !
Unplug it.Written on drive it will show you how to set it to a slve drive.put it into another computer. ????????? It's a starting point.
Posted on Apr 18, 2013
NO read access for C drive or CD/DVD drive
Check the Drivers. You may have a problem there. Go to Control Panel/Devices/DV/CDROM drives. Update the Drivers from there.
Feb 19, 2014 | Computers & Internet
Seagate freeagent Go 640 gb not being reconised on my computer can't access important files
Try using a different computer to access the hard drive. If another computer cannot access the hard drive, then most likely the hard drive itself is corrupted, and you need to reformat or replace it.
Mar 02, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
WD 10EADS external USB 1TB HDD. Using XP windows explorer, selecting drive returns a comment that it is not formatted. Using Windows98 explorer gives brief correct directory display but there are...
Sounds like you may have a corrupted drive or that the file catalogue on the drive is corrupted. Try accessing the drive on a different machine, if you can suspect the usb ports or the cable from the drive, if you still cannot gain access, the drive is corrupted. There are people who can extract the data off a corrupted drive but this is expensive so if you dont really need the data on the drive, reformat and start again..
Mar 17, 2010 | Computers & Internet
Why won't the Kenmore top loading washing machine agitate?
There are two types of Kenmore top loading washing machines. The direct drive models and the belt drive models. Direct drive models do not have a back access panel and the water inlet valve is located on the left side viewed from the rear while belt drive models do have back access panel and the water inlet valve is located on the right side viewed from the rear.
The most common problem causing a top loading machine not to agitate, particularly when the motor seems running, is a broken motor coupler for direct drive models and a broken or worn out drive belt for belt drive models.
The best way to exactly determine the cause is to access the drive motor. Open the back access panel for belt drive models and check the drive belt. Check the drive motor if it is running, humming or stuck.
Please indicate the model number of the washing machine if it is a direct drive model for the procedure in accessing drive motor.
Jan 15, 2010 | Washing Machines
I cant access the d partition on my hard drive
Hi...
Do you want to access the drive d and get your files. You can not access it when you double click the drive. The drive will says access denied. To access the drive d open My Computer you can see there a address, there is and arrow there just click. Chose the drive d to open i am sure that you can open it.
Regards
PCmania
Aug 27, 2009 | Computers & Internet
Local drive not accessible
hi,
just format your local drive
rate my suggestion
Aug 27, 2009 | Microsoft Windows Vista Ultimate Edition
In my system have c,d, e, and f drives.i can access c,d,e and but i can't access the f drive..while accessing my f drive ''f: drive is not accessible''.access denied.but it appeare in local disk manag on...
just format the drive and check . After that if the drive not opened then go to disk manager and delete that drive and again creat the drive then check
Jun 08, 2009 | Computers & Internet
The hard disk in drive D: is not accessible
I recently had this problem. Whenever I clicked on any of the drives a window appeared with warning which said drive not accessible. Access is denied. Previously I thought that it is a virus which has edited my registry and is not allowing me to enter or even view my content. So I formatted the whole system but that didn't help. Now I am sharing this with you.
  1. Open My Computer. Goto Tools>Options. Goto View Tab Pane. Uncheck the last Option in the Advanced Setting which says Use simple file sharing(Recommended). Apply the setting.
  2. Open the properties window of the drive you are unable to access.Goto Security tab pane.
  3. Goto Advanced.
  4. Now click on the Owner tab pane.
  5. It's very rare that the ownership of the drive changes. But it happens once in a while.
  6. So if you are the user say Admin then select Admin(ComputerName\Administrator).
  7. Click on the box which says Replace owner on subcontainers and objects and click over Ok.
  8. Apply the changes.
  9. Now you should be able to access the drive.
Feb 18, 2008 | Samsung (SP0822N) 80 GB Hard Drive
Computers & Internet Logo
Alun Cox
