Question about Technics Audio Players & Recorders
I,ve got a technics sl-ps670d cd player which has just started to play slightly slower, any idea,s on a fix
Plays noticeably slower since the last time I played it which was last night
  • 112 Answers
SOURCE: technics 5 cd changer sl-pd787
Does it show the disc length or any other details? Have you carefully cleaned the lense with a q-tip and some alcohol? Can you hear the laser moving in and out of focus? If you push the laser sled out away from the centre does it move back to the middle when youi put a disc in?
Posted on Feb 29, 2008
  • 6 Answers
SOURCE: Technics 5 cd changer Model sl-pc11 will pick up
System will not play Mp3 or data format cds.
Audio cds only . Also Clean lenses with a cd lenses cleaner .
clean cd also straight away from center ,soft cloth
Check for scratches .
Posted on Mar 01, 2009
SOURCE: CD player acknowledge CD, starts to play, then stops
replace belt in lazar assembly and clean lazar eye with quetip with rubbing alchol
Posted on Oct 07, 2009
SOURCE: My Technics SL-DZ1200 will not play certain MP3
I believe it can only read certain bitrates. I noticed that if I run the track error files through audacity and re-save as an mp3 with 192 kbps encoding it plays fine. Give it a try - re-encoding.
Posted on Nov 12, 2009
  • 99 Answers
SOURCE: technics sl-pg580A
this player uses a philips mechanism, spindle motor failure is very common on these mechanisms, yours may be on its way out. take the lid off and insert a cd and if you can hear the laser trying to read the cd without it spinning, it's definately the spindle motor.
Posted on Dec 20, 2009
I have a Technics CD changer SL-PD867 it will not play re writable disc's any other disc ok
Not all CD players can or will play CD's burned in a PC. Sometimes the CD player is to old, so not compatible with these CDs. Sometimes the player just does not play these CD's, because of rights protection.
A CD burned in a PC is less reflective than an normal music CD. Normal CD's do have a metal coating and are highly reflective. Burned CD's have a dye, and where the laser burned the dye, it only changed colour. Making it less reflective.
All modern CD playes should be capable of playing CD r's. But the player that is really compatible, is labelled CDr and CDrw compatible.
May 11, 2014 | Technics SL-DZ1200 CD Player
Hi i have a techniqka hi fi MC-208 when i put a cd in it plays for a bit then 0P shows on the wee window so i cnt play cd... How can i resolve this... Thanks Kerry
try to turn it off an on while holding the play button. try 2 go online an look for the meaning of your (op). type in .technics sl-mc-208 cd player 0P problem
Mar 15, 2011 | Technics SL-MC50 CD Player
I have a Technics SL-PG480A CD player. It won't play CDs down loaded from i tunes. These CDs will play on another newer Sony. The Technics plays other commercial Cds without problem both before and after...
This player will not play either MP3 or MP4 encoded CdRs. It is a good 18 years old now and such things were unforeseen back in the day. The newer sony may well be MP3 compatible. You could convert MP4 to standard audio types on your pc via any number of software applications.
Dec 23, 2010 | Technics SL-PG480A CD Player
Disc will not play appears to be skipping
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Be sure discs are free of dust and scratches.
Apr 27, 2010 | Technics SL-PD6 5-Disc CD Changer
Does the Technics SL-MC6 play home made CD's? CD-R? CD-RW?
i've not come across a technics cd player yet that doesn't play cd-rs but they definatly don't play cd-rws.
Aug 02, 2009 | Technics SL-MC6 CD Player
My Technics SL-DZ1200 will not play certain MP3 tracks. It will play some, but on others the message "track error" appears. these same disks will play just fine on the other cd player machines I have...
Jun 08, 2009 | Technics SL-DZ1200 CD Player
CD's come out distorted on the TECHNICS SL PG 580A
TRY NEW RCA JACKS AND TRY BLOWING IT OUT,,GET YOU A LASER LENS CLEANER
Feb 26, 2009 | Technics SL-PG480A CD Player
Technics sl-pg580A
Oct 07, 2008 | Technics SL-PG480A CD Player
Technics SL PJ27
First I think you should turn your player on and wait 5 - 40 minutes before before you start liste3ning music.
because electrolytic capasitors may be little broken and those can repair themselves but it takes a while.
Good rule of thumb is that If you don't use every day an old device
then you should give to it every time a soft start . like I mentioned earlier
turn power on and wait.
Second try to play music cd which don't have any scratches and without any copyprotections
Third Disconnect power cable
Then open device and try to clean all dust.
Look for hairs and other difficult to see objects uselly
you find at least one hair inside old cd player.
If hair is around disk spindle it maybe difficult to
remove.
Check that cd-disk makes good contact so remove even tiniest dust and hairs
between cd-player and copact-disk. It may be called spindle or what ever but
still try to clean it with Isopropyl alcohol and remove dust and filth.
Check laserlens and is there some dryed liquid stains if there is try to remove those
with Isopropyl alcohol and swabs. Don't use any force and you can tear a top of swab little longer
(about one inch) and you get swabs which are much easier to use these kind of delicate cleanings.
Lubricate every moving part with lithiumgreese don't make any mess.
This last fix is for most desperate ones.
Connect the power cable and push eject and be carefull because
you can get fatal electric shock.
Disconect power cable. You can use extension cord which have on/off powerswitch.
You can see six tiny trim pots.
First take photo of those pots so you can undo all changes.
Change only one pot and only about 1/8 of turn. Turn power on and test if you make it worst or better.
If you think you fixed the problem that is not the case ... yet.
Then you have to make finall test and play a lot of music cd:s and after that you have fixed the problem.
Make notes which cd:s and what track your player don't play properly and use those
cd:s to testing those trimpot changes.
Dec 25, 2007 | Technics SL-PD5 5-Disc CD Changer
Technics SL-MC7 / Can't play cd's any more!
Friend. Did you try a CD that you purchased from the store? if so and this problem persist, then you need to get you a new player. If the CDs are scratched, some players will not play them, If they are burnt in mp3 format, (or data format) your player may not recognised this also. Please try playig a regular CD that you bought from the store, if this work, then you will need to reburn your music as a regular CD, hoping that the SL-MC700. reads copied. It should. But please checks these steps.
Please let me know what works.
Thank you
Dec 08, 2007 | Technics SL-MC700 110-Disc CD Changer
129 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
