Question about Mastervision BVCFM2503 - Dry Erase Magnetic Tape Strips, Yellow,
Where can I purchase magnetic easel strips that adhere to a wall?
Do you think its safe to use clear wall tacks in a pre school class? Isn't Scotch Tape safer on walls not made for tacks?
I would never use tacks or any type of sharp object in a preschool classroom. There are so many other ways to mount things that make more sense. For instance, many white boards are magnetic and you can use large magnets (avoid small ones which could be swallowed) and 3M makes dozens of mounting products that are clear, don't ruin wall surfaces, and are non toxic should a child decide they want to put one in their mouth. As a general rule if you can take an object, poke yourself with it, and bleed, it shouldn't be in a preschool classroom.
By the way, Scotch tape is not a good choice for sticking things to walls. In many cases, it's not strong enough to adhere to the wall, and if it's a painted wall, it will take the paint off the wall.
Jan 04, 2017 | Preschool
I have a whirlpool tub, with a side panel that allows access to the mechanics, and the panel is just held on with cheap velcro. We put commercial grade velcro on, as the panel kept falling off, but it too...
If Velcro is not working for you try some magnetic strips. Purchase some magnetic strips attach to both the cover and the tub. Be sure the polarity of the magnetic strips is correct so they attract each other. You could glue the strips to the cover attach the tub strips to the cover strips then apply glue to the tub strips and apply the cover to the tub allow the glue to dry and that would insure correct polarity and positioning of the strips. Hope this helps.
Bob
Aug 22, 2014 | Home
What does it mean that an easel is convertible easel?
It means that the easel is able to be converted from the standard easel into a table top. These are really useful for if you like to work on different surfaces. like the one you see here.
Sep 15, 2013 | Office Equipment & Supplies
Is it difficult to make a homemade art easel?
No, its very easy. If you want to make a sturdy wooden easel, follow the instructions on this link:
http://www.ehow.com/how_5553540_make-homemade-artists-easel.html
you can also make more disposable easels out of cardboard:
http://www.enchantedlearning.com/crafts/Easel.shtml
Feb 19, 2013 | Crafts & Hobbies
Should I purchase a tabletop easel?
Tabletop easel intended for artists who are short on space but still wish to create a quality art. If you are one of them, tabletop easel is the best thing you can purchase for yourself. It will take maximum advantage of the limited space you have and make it much more comfortable for you.
Feb 03, 2013 | Crafts & Hobbies
Where can I find a wooden easel with a drawer?
Try this website: http://www.winsornewton.com/products/easels/ or you can also find them on ebay: http://www.ebay.com/sch/Easels-/41204/i.html
Jan 24, 2013 | Office Equipment & Supplies
Where can replacement parts be brought for the Crayola Magnetic Double Easel
n order to make the art trays stay on the easel (several people have complained that they easily fall off), you have to reach behind (inside) the easel and snap them on. You don't just sit them on; they snap in place. Do this and they won't keep falling off. : ) if thats the problem....there are no replacement parts...
May 18, 2011 | Crayola Toys
How to fold Roseart Smart Easel ??????
Lift right side of top bar of easel. remove horizontal support bar at back and bottom of easel legs. Push fabric down slightly on back curved legs of easel. Find tiny silver button on the inside of each back leg and push each as you wiggle and pull leg apart. look for hinged bar in middle back of easel and push up. Easel should easily fold on itself so you can put it into the bag.
Dec 15, 2010 | Roseart Rose Art Smart Easel Kid's...
I am trying to use the vhb 4941 to adhere a magnet to the dashboard of my car. I have used isopropal alcohol and denatured alcohol to clean the dash but I still cannot get the tape to stick. Any...
Try using contact cement. Apply to both surfaces and ALLOW TO DRY. Next time the pieces touch, they will stick, so place VERY carefully...Another material is weather strip adhesive. works the same. Consider masking tape to keep mess to a minimum.
and you can use water base contact, it works as well or better than the old tar like stuff.
Nov 11, 2010 | GPS
Door will not close, magnetic strip won't adhere, and air does not **** door shut
Change the magnetic gasket from a good service center or you may change it yourself. Thanks.
Sep 29, 2009 | Frigidaire 20.3 cu. ft. Upright Freezer...
Mastervision BVCFM2503 - Dry Erase Magnetic Tape Strips, Yellow, Logo
545 people viewed this question
Top Mastervision Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mastervision Office Equipment and Supply Expert? Answer questions, earn points and help others
