Question about Garden
I have a tecumseh engine troy built when i try to start it fuel runs out the muffler
    Filmmaker:
    Uploaded 5 video answers.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 84 Answers
It is floodd bad
Posted on Jun 16, 2013
  • 69 Answers
SOURCE: i have an old troy built mower with a tecumseh
Try checking the Troybuilt website for a manual on your tiller.
www.troybuilt.com
Posted on May 06, 2009
  • 69 Answers
SOURCE: does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Remag1234
  • 387 Answers
SOURCE: I have 1980's model troy built pony tiller that won't fire
Great machine, I had one. The points need replacement. Look for a gadget that replaces the points. I found mine in PepBoys. Search the Internet, the cost was about $5.00.
Posted on May 17, 2009
  • 468 Answers
SOURCE: Troy Bilt Tiller and Pressure Washer
The carbs are plugged. Take the bowl off the carburetor by loosening the nut on the bottom. You'll want to clamp the fuel line before you do this. That nut has a small hole that goes through the nut from side to side, and one that connects them in the center. Use a wire brush to knock all the deposits loose, making sure that the holes are clean and free of obstruction. Put it all back together, and it should run fine.
Posted on Feb 01, 2010
  • 52 Answers
SOURCE: small hole on carbuerator opposite where gas hose connects leaks
perhaps there was a hose on/in it at one time cause it sounds like an over flow/vent.
Posted on Apr 18, 2010
How do I fix a surging Tecumseh engine on my 1988 Troy-bilt rotor tiller?
Clogged fuel inlet line or fuel filter. It's not getting enough fuel to run
May 09, 2015 | Troy-Bilt Garden
Troy Built tiller Tecumseh engine carburetor linkage
I've got one of these that I'm working on myself right now, and all the carb linkage from air vane to springs was gone. I had no info. on this TC-2 engine myself. I found a couple of free service manuals from Tecumseh by Googleing Tecumseh TC-2. And then partstree.com has a lot of good parts break downs, I take the parts numbers I need here and then order through my local dealer.
Hope this helps some what and GOOD LUCK.
Oct 13, 2014 | Troy Garden
Gasoline runs through carb and out muffler
The needle valve isn't seating and sealing off the flow of fuel, you also need to check your oil to make sure it doesn't have fuel mixed in with the oil, it can ruin your engine, quick fix install an inline fuel shut off valve and turn it off when you shut the engine off, and this will fix the problem.
Aug 14, 2014 | Troy Bilt 22HP Hydrostatic 46" Riding...
What else could cause my troybilt cultivator to not run?
spay starting fluid in the air filter if it fires then you have a carb/fuel problem (keep in mind small engines need fuel 30 days or newer )if no fire on starting fluid check for spark if you have spark good fresh fuel remove the muffler and try it again if it runs with the muffler off then open the muffler and clean the screen iside
Jun 06, 2012 | Troy-Bilt Garden
I have a troy built chipper schredder vac built by garden way in 1992 that has a tecumseh engine model h50-65578t that i would like the carb adjustments .
start at one and a half turns each ,run at full throttle turn outhigh speed screw (bottom) until it starts running flat, turn back untill runs clean. same procedure for low speed screw but at idle speed .when done turn throttle to high speed if boggs open low speed screw alittle bit at a time untill accelerates with out bogging hope this helps
Aug 09, 2010 | Troy Bilt Builtchipper...
My troy-built blower will not start
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 26, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
I have a troy bilt tiller with a 2hp motor.lately i have had to run it with the choke on and then when i engage the tines it will go dead.have any ideas thanks the engine is a tecumseh
You can check the linkage that links the governor to the carb. If that is fine then you can check the fuel line for a blockage, the carburetor for debris, and if that is fine then you may want to try sanding the rust off the magnet (on the fly-wheel).
May 10, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Free wheel
Shift your Wheel gear lever to "disengage". Use the disengage position only when the engine is not running.
Apr 19, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Hard to start and backfires from muffler when running
Sounds like the timing may be off or maybethe exhaust valve maybe hanging open.
Mar 15, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
