Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox tv Won't auto program channels.
  • Philips Master
  • 3,459 Answers
Recheck your cable TV hookups....
Posted on Apr 19, 2013
My Magnavox T.V won't allow me to watch actaul Tv
you will need to tuned every channel then save it to the memory. you can use the user manual of your tv for instructions. if you don't have user manual i'll try find from you, just give me the model of your tv.
Nov 03, 2012 | Televison & Video
I have a Magnavox digital converter box that won't
if channel is ok when you use only an aerial antenna the cause it could be in the digital converter but if the same problem the cause would be in the channel program.
Oct 15, 2012 | Televison & Video
My Sanyo TV won't scan every channels that my other TV's scan!
check weather some of your channel was deleted in the program. just add those channel so you can make auto scan programs.
Oct 07, 2012 | Sanyo DP46849 46 in. HDTV
Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Oct 07, 2012 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
I have a LG 32ld333h tv it won't auto tune and doesn't have a add/delete how do i get it to program channels
You sir have a hospitality tv used only in hotels and motels proidium tv type that needs a master remote or call best buy to reset to consumer type tv from commer
Aug 25, 2012 | LG Televison & Video
My 1996 Magnavox 25" TV won't work
It sounds that the tuner to your TV is faulty. A detail check is necessary to confirm. Seek expert tech support.
Jun 20, 2012 | Philips Magnavox 13MT143S 13" TV
Olevia tv won't auto program you can punch in numbers but you cannot channel up it goes into mute
problem with keyboard on set front or side===likely defective switches under the plastic buttons.
May 13, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Philips Magnavox 2783 c101 - will not auto program tv channels
Ya what you got to do is Grab your tv, and throw it out your window. Garbage tv with built in problems made to be fixed. I had the same tv and i had many problems with it before. Just buy a new one boss.
Feb 17, 2010 | Philips Televison & Video
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
100 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
