Question about Gigabyte Computers & Internet
CANNOT INSTALL XP HOME
BIOS 0NE BIP OK.IT'S HD VIRGIN . I START INSTALLATION XP AND WHEN I RESTART (TAKE CD XP OFF) AND REPLACE CD I SEE INSTALLATION STEP 3 AND HE JAM FREEZ HE IS STUCK NOTHINGELSE TO DO
    President:
  • 1,073 Answers
Why do you revove the cd? DONT do that, just let the installation go on until it finish.
When xp restarts you will be asked if you want to start from the cd, if you do press any key, DONT press anything at all, let the system starts from the point of installation that it needs.
BTW, did you set the boot correct? boot ONE the cd/dvd, boot TWO the HDD
Good luck
Nic
Posted on Mar 11, 2009
ASUS EeePc 1015PEM reboots at windows startup. even with new hdd and fresh install. ok when in bios screen or if i boot into linyx
Which windows OS are you using? windows xp, 7 or 8?
Anyway the problem might be corrupted installation CD. If you install windows on other computer using this CD, so if CD is OK, then
start your laptop and press F8 repeatedly until Windows Advanced Boot Options appears. Then choose automatic restart on system failure. This option will allow you to see Blue Screen Of Death and to understand what causes a problem.
Sep 21, 2013 | ASUS - EEEPC Eee PC 1015pem-pu17-wt...
Tip
How To Repair Your Operating System
A Repair Install will replace the system files with the files on the XP CD used for the Repair Install. It will leave your applications and settings intact, but Windows updates will need to be reapplied. Here is how to run an OS Repair using the Operating System CD in XP, Vista, or 7:
Windows XP
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below:
3. Press ENTER to start the Windows Setup.
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Windows Vista
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
Here is a step by step picture guide.
If you have a Windows Vista installation disc:
1. Insert the installation disc.
2. Restart your computer.
3. Click the Start button, click the arrow next to the Lock button, and then click Restart.
4. If prompted, press any key to start Windows from the installation disc.
Windows 7
1. If a startup problem is detected, Startup Repair will start automatically and try to fix the problem.
2. If the problem is severe enough that Startup Repair doesn't start on its own and you can't access the System Recovery Options menu on your computer's hard disk, you can get to the menu and start Startup Repair by using the Windows installation disc or a system repair disc that you created earlier.
on Jul 13, 2010 | Computers & Internet
How do I install WindowsXP
You need a Windows XP installation CD plus the product installation code.
If you do not have a Windows XP Pro installation CD then you maybe able to get one on the internet.
To install Windows XP, boot up your laptop with the Windows installation CD and follow the instructions.
May 20, 2012 | Computers & Internet
I want to install Windows XP on Sony Vaio VGN CS15GN B instead of Windows Vista but it is not happening kindly help
---------------> Perform a clean install of Windows XP 1)- Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
2)- When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
3)- At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4)- Read the Microsoft Software License Terms, and then press F8.
5)- Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
6)- Follow the instructions on the screen to complete the Windows XP Setup.
Note:- Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
May 25, 2011 | Computers & Internet
I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell...
All you've got to do is:
1) Insert the new hard drive.
2) Press the F8 key as the laptop boots. This will take you into the BIOS.
3) Locate the disk drive priority setting in the bios.
4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
5) Save settings and exit the BIOS. This should reboot your laptop.
6) Insert the Windows XP CD.
7) It should not start the setup as it recognises the CD.
8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
9) After the format it will reboot your system.
10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
11) Now it should start the install. Follow the on-screen instructions.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
I want to change my windows xp to Home edition
You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
Oct 27, 2010 | Microsoft Windows XP Professional
I have a problem with my PC: When I try to turn off the windows XP home edition SP3 the pc don't stop he restart, but i think the HDD C: where windows is install stop and then restart all sistem (like in...
It Seems Some System Files are Corrupted or Deleted By Antivirus Application in the Process of Removing Virus from your System ....
Method 1:
1. Put your Windows XP CD in your CD-Drive
2. Open RUN Dialogue Box From Start Menu
3. Type "SFC /SCANNOW" -- Copy and Paste the Command exactly
With out Quotes
4. Wait Until It Completes everything...
5.Restart and Check your Problem ....
Method 2:
1.Login to your Windows XP
2. Put your Windows XP Home CD in your CD-Drive
3. Click Install Windows XP From Autorun Window.Start Windows XP Autorun Screen if its not opened, by Clicking on the Windows XP CD Drive icon under your My Computer ...
4.Select Same Drive as your Windows XP Now Installed then Select Upgrade Method to Install...
5.Complete Installation and Restart your System ...
Note: in Upgrade You'll never lost your Installed Programs and Files ...
Feb 20, 2010 | Microsoft Windows XP Home Edition
When I restart my computer and after I enter my
Probably your system has been corrupted, or you have installed a software that caused your system not to function due to conflicts.
The solution that i find to solve your problem is to perform windows xp repair install, which will replace corrupted files on your system in order for you system to run properly.
Follow these step by step solution on how to perform the Windows XP Repair Install.
You should first check if you have these on your system.
1. A CD/DVD Drive.
2. A bootable Windows XP Install disk, depends on the version of your Windows XP , whether it be SP3 or SP2.
3.Idea on how to boot to your BIOS settings, you can check it using your systems manual or you should see a press button (e.g "Press F2 to SETUP").
Step by step solution on performing Windows XP Repair Install.
1. Insert the Windows XP installer on your CD/DVD Drive.
2. Restart your system.
3. Go to your BIOS Settings and set your CD/DVD drive boot priority. We will be booting to your Windows XP Install disk to perform reinstall on your system.
* Reinstalling doesnt affect your programs, but will just delete the previous windows xp system files and replace it with a new one.
4. When you are now in the Windows XP Install screen where you can select if you want to install windows xp, go to windows repair console or exit the installation. You should select "to Setup windows XP now press Enter".
Heres the screenshot as a guide.
Press Enter, then when you see Searching for previous windows installation, you should select "R" to repair your installation, if you dont see any "searching for previous windows installation message" then you should check your bios settings.
After the reboot, you should set back again your BIOS to boot from your hard drive. restart your system, also you should prepare a valid windows xp cd key for that because you will be needing it confirm the setup process of your system.
After the reinstallation process, you can now boot your windows xp system nice and clean. :)
Jan 24, 2010 | Dell Inspiron 1501 Notebook
Hard Drive Prevents any other windows device from loading
Hi, Mark Here.
Yes the setup on the xp install puts drivers into memory, but being an older version of windows B4 sta was out it does not have drivers to support it.
You could go to Microsoft & search for a new version of setup install drivers that includes sta, & download to thumb.
Really typical Windows Failure (driver not available freeze up or blue screen).
Mar 22, 2009 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
