Question about Dragon Syma 9093 fly RC Helicopter Tail Boom + Tail Motor Combo Set
Helicopter syma 9093 dragonfly tail pinion detached from shaft
After many flights, suddenly the tail rotor does not spin. I found that the tail motor shaft spins on itself and does not 'trasmit the movement' to the tail white plastic drive gear. The motor metal pinion is not anymore attached to the motor shaft. Pinion-plastic gear alignment is ok. Any suggestion? I guess I cannot simply glue them.. If I buy a new motor, will it come with the pinion firmly attached? Thanx
I have a s033g helicopter with about 20 flights on it now I can get it off the ground ive changed chargers, batteries, control and just changed both motors with the same results no flight. any...
Have you checked that the main gears are not slipping as it only takes the drive on one set of blades to slip and you will not have enough powere to take off even though it seems both sets of rotors are spinning.
Kind regards, Julian
Sep 13, 2013 | SYMA Toys industrial New Syma S107 Radio...
Ir helicopter only upper wing spinning
Have a SATURN-X 2CH IR and the tail and the tail rotor will not spin? What can I do?
Dec 30, 2012 | Worldtech Devices World Tech 85618 2CH...
How do I change the tail rotor on a syma s107
Carefully, while holding the silver metal motor in place, gently pull the rotor off of the rear drive shaft. Place new one on and push it gently into place. If it is loose, you can secure it with a VERY CAREFULLY applied mini-drop of super glue. Turn helicopter upside down and use as little glue as possible, keep it away from where the shaft meets the motor, and keep upside down until glue dries fully.
Hope this helps,
Jul 21, 2011 | SYMA Toys industrial New Syma S107 Mini...
The tail rotor on my Syma s107 metal series helicopter won't spin. the battery is fully charged. the top rotor still spins. i don't know what to do
It seems tail motor is not working.
S107 knows to come with faulty tail motor.
If you open pilot cabin, you should see blue and red (or green and red) wire. See if they are welded on the motherboard.
If they are, then tail rotor is not working properly.
Mar 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
SYMA S107 Helicopter. Advertised as 3 channel. Remote has channel marking of A B C, but the switch is only 2 position. How do you achieve 3 channels with only 2 position switch?
This helicopter have 2 channels I see.
Maybe A-B is first position and B-C is secound position channel. Helicopter have not switch ABC, simply turn off and turn on for change channel.
Jan 14, 2011 | SYMA Toys industrial New Syma S107 Mini...
Brand new unit forward and reverse seems very slow moves a little then just hovers.
Make sure you're charging fully, until the light on the charger doesn't get ANY brighter when you unplug the helicopter. Also, battery must be allowed to cool 10 minutes after flying AND another 10 minutes after charging.
Most crucial is that you must never fully discharge battery. Fully draining a Li/Po even once (especially when it's new) can cripple or ruin your battery. As soon as you are unable to maintain altitude, land copter and power it off. Also, there is a button on the remote, labelled "tail motor speed switch" located near the trim control. With it in the "off" or up position the tail motor is much slower allowing for more precise control. When button is pushed to the down or "on" position, tail motor moves faster giving more tilt, and thereby much more forward/reverse 'thrust'. Verify that tail rotor is moving when right joystick is actuated (and that it reverses when right stick is pulled in opposite direction) and that it isn't loose on it's shaft... this can be tested by verifying tail rotor spin in one direction then reversing joystick... tail rotor should instantly start spinning in the other direction with NO hesitation, if it slows and then starts spinning in other direction or anything like that then it's loose. Turn helicopter upside down then VERY CAREFULLY apply a small drop of super glue where the shaft meets the tail rotor, be very cautious to not get any glue near where the shaft comes out of the motor, and do not turn right side up until glue is fully dry.
Hope this helps,
Jan 07, 2011 | SYMA Toys industrial Syma S032 Ready to...
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
RC Helicopter ( HoverLites ) AKA "Syma 9093" Need Parts .. In Ontario Canada
Hi Graham
See the link. There are RC Helicopter parts stores a bit further south of Barrie. There is one in Mississauga where I am.
electric rc helicopter parts canada Google Search
Dec 24, 2017 | Optics
Hover Lites RAdio-Controlled Helicopter
19511 Pauling Street Foothill Ranch CALIFORNIA 92610
Mike Roberts, Partner and Co-founder of MerchSource, LLC
Mike Roberts, 949-900-0904
RE: Hover Lites Radio Controlled Helicopter parts
I have/had the same problems as everyone else.. I found that this helicopter is the same as 9093 Syma RC Helicopter, here is the site where you can get parts!
Nov 11, 2007 | Optics
Dragon Syma 9093 fly RC Helicopter Tail Boom + Tail Motor Combo Set Logo
Top Dragon Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Dragon Toy Expert? Answer questions, earn points and help others
