Question about Zanussi ZWF1230W Front Load Washer
Hi I have a Zanussi Aquacycle 1050, and it's started to leak from inside the drum I think when fulling up, the front door seal is fine, any ideas what it could be and how I could fix the problem?
  • 1 more comment
  • paul_kyle Mar 16, 2009
    Was helpful, but it's not the inlet valve, the leak is coming from the bottom of the brum through the concert holder on the front. It doesn't leak until its5mins into the wash?
    but thanks for your help...
    It looks like the leak is coming through the counterweight, so would it be a problem with the boot seal or some thing else?
  • paul_kyle Mar 17, 2009
    How easy is it to replace?
    President:
  • 1,294 Answers
This is your inlet valve which is defective. It leaks even if the machine is off? Plug off the wall socket. Check to see if the wires are in their harness connected well. If this is not the problem change the inlet valve, it is easily done.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 11, 2009
  • prem mathew Mar 16, 2009
    Probably leak in the boot seal, near drum.
  • prem mathew Mar 18, 2009
    You sure it's the door seal, you could do it yourself, not so easy but you can. Goes like this for another zanu:
    Plug off the wall. Remove plastic clamp holding seal to cabinet and peel off the cabinet. Push downwards on the seal close to the tub and the seal will come off - its just held by a spring round the periphery.
    To fit new seal.
    Lubricate the slot which fits over the tub with washing-up fluid. Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange. When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. This is quite difficult and you may need another pair of hands. Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
    Test for leaks before using in earnest. Use rinse to test as the water level is higher.
Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Dec 31, 2009 | Zanussi ZWF1230W Front Load Washer
Horrible scraping noice when drum rotates
YOU WILL NEED TO REMOVE DOOR SEALING RUBBER WHICH SEALS THE TWO HALFS OF THE DRUM THIS WILL ALOW YOU TO REMOVE SAID OBJECT
Dec 28, 2009 | Washing Machines
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
I HAVE A ZANUSSI XC AQUACYCLE 1000 FRONT DOOR
broken circuit in printed circuit board
Aug 11, 2009 | Zanussi Washing Machines
I think the bearings have gone on my zanussi aquacycle fls 1183w. can i do this myself, or do i need a new machine.
I have just done this myself and to be honest it was quite easy.
you will need bearings l replaced both front and rear as the cost of each was nothing, a new bearing seal and a drum gasket as the drum has to come apart.
Tools are a digital camera ,socket set, torx key set, set of spanners a cold chisel and a hammer. And you need the old bearings to put the new ones in
Jun 06, 2009 | Zanussi ZWF1420W Front Load Washer
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
Door
it probabbly broke somewhere.
if it is possible to take the handle out, I would investigate the problem further.
not worth fixing the handle, you may have to get a replacement.
Mar 16, 2008 | Washing Machines
Zanussi aquacycle 1050 not turning on
First try another gadget, a lamp or something on the wall plug, to see if the point is live. Then check your washer plug, could be that the fuse in the plug has blown, check out your washer wire....
Jan 06, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi aquacycle 1200
May be the Bearings.Open door and try moving drum, hold at top of drum and pull foreword and back if drum loose main bearings gon. Replace bearings.
Slim Jim
Oct 28, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1230W Front Load Washer Logo
568 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
