Question about Ricoh Aficio CL-1000N Color Network Laser Printer, 402064
Ricoh sc380 error - Ricoh Aficio CL-1000N Color Network Laser Printer, 402064
  • gerpablo2
    gerpablo2 Apr 18, 2013
    my ricoh cl1000 show sc380 error, what it means
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Fix an EE error
That means that the scale cannot calibrate itself. When it turns on it checks the sensors to see if they are in range. It cannot find the sensors or they are out of range.
Nov 03, 2015 | Homedics SC380 Scale
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
Smearned Printing on Ricoh Aficio AP3800C Laser Printer
Hi there the smudges are most likely down to the black PCU (Drum Unit) and following are the reasons for the two fault caode you have given me.
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
actuator
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
sensor.
5. Check and/or replace the PSU.
SC 380 Black
development
motor error
SC 381 Color
development
motor error
When the motor speed is
within the target level, the
motor sends a lock signal
(High to Low at CN214-5) to
the BCU.
SC380 is detected under the
following conditions:
• The Lock signal stays High
2 seconds after the motor
turns on.
• The Lock signal stays Low 2
turns off.
for more than 2 seconds
while the motor is on.
• Defective motor
• Defective BCU
2. Replace the motor.
3. Replace the BCU.
Hope this is any help
Thanks J
Feb 21, 2008 | Ricoh Aficio AP3800C Laser Printer
Sc error 380 and fuser breakdown
Hi there you will need to replace the development motor but first try the following.
Entering the Service Mode
There are two ways to enter the service mode.
Method 1: Turn the machine on while pressing the “On Line” key and “Escape” key
together until the above message in the illustration appears on the display.
NOTE: If you switch the machine off, any jobs stored on the hard disk using the
sample print and protected print features will be deleted.
Check first with the user tools to see if there are any jobs stored with these
features
(Menu key - Sample Print, or Protected Print).
Method 2: Press the “Up/Down arrow” keys together for about 5 seconds, then
press the “Enter” key.
The above message shown in the illustration appears on the display.
NOTE: The machine automatically goes off line when you enter the service mode.
Using the up down arrows select Engine and enter by pressing enter or # key.
Using the up down arrows select mode 5 then enter using enter or # key then select 810 (SC reset) press enter then if you want to select 809 (SC Detection ON/OFF) Enter and select 1 to disable. Escape or return key all the way out and exit. Turn the machine off then on again and test if the same problem then replace the Dev unit if still having the problem then replacement of the motor likely. I can email you the complete service manual if you like.
Thanks J
Jan 19, 2008 | Ricoh Aficio AP3800C Laser Printer
SC380 and fuser unit break down
features
Thanks J
Fuser unit breakdown error sc380
features
Thanks J
Ricoh Aficio CL-1000N Color Network Laser Printer, 402064 Logo
42 people viewed this question
Top Ricoh Computers & Internet Experts
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
