Question about Keurig B50 Coffee Maker
It had the add water light on so i did and t won"t turn off the indicator light
Added water. light still flashng. Not ready tp brew.
  • 1,511 Answers
Requires cleaning and flushing
Posted on Jan 31, 2014
  • 2039 Answers
SOURCE: add water
emty the water shake the machine in our hand the water float is probably stuck try it after use product that gonna get ride of calcium
Posted on Jan 16, 2008
SOURCE: ADD WATER LIGHT WON'T GO OFF
What espresso make do you have? I just posted the same question! Mine won't work either and its so frustrating...I called the nuova simonelli tech guy and he said that it sounded like the water I was using wasn't hard enough, but I have well water...so basically they don't know whats wrong.
Posted on Apr 13, 2009
  • 5 Answers
SOURCE: WIll not brew
Try this, worked for me:
Just today we've found that at the first water intake (on my B60, that's where the water container plugs into the base) on the base is a little circle valve type thing. That's where the water gets sucked out of the tank. Shine a flashlight into that circle, and you'll see a screen type thing there. It's like the screen in your faucet when you unscrew the tip and there are little rocks and stuff in it? Same principle: there were cotton fibers and other assorted weird stuff clogging that screen. Used a toothpick or a needle and removed all the debris from the screen, and it now works perfectly!
Posted on Feb 18, 2010
  • 58 Answers
SOURCE: coffee maker is indicating not ready add water
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
espressonist
  • 1711 Answers
SOURCE: Not brewing. Plenty of water, says ready to brew,
You can try this
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
http://www.youtube.com/watch?v=DqRs4Ott21s
Posted on Mar 28, 2011
Single serve flashes but does not brew
It's always best to give the model number of the appliance when asking questions about problems. Here's what a general troubleshooting procedure that might find the problem:
(1) Every once in a while an air bubble may get trapped in the water path. Lift off the reservoir, then put it back into place.
(2) Turn off and unplug the brewer for a couple of minutes or more. When you plug the brewer back in, be sure to turn the power back on.
(3) Make sure the water reservoir is properly in place, and perform a Rinse cycle.
(4) After placing the K-Cup® in the K-Cup® Holder, make sure the handle is pushed down securely and the LCD control panel reads READY. The and buttons, Brew, Hot Water, and Rinse buttons will be illuminated. Then press any of the lit buttons.
(5) If the LCD control panel indicates ADD WATER, check to make sure the water reservoir is properly filled. If not, add water. If so, make sure the water reservoir is properly seated in its base.
(6) If the LCD control panel indicates ADD WATER even after refilling and checking the base, contact Customer Service at 1-800-726-0190.
(7) The exit needle may be clogged (refer to page 19).
Sep 11, 2016 | Cuisinart Coffee Makers & Espresso...
After de-scaling my girlfriend's keurig mini, the 'add water' indicator does not function properly. It always thinks there is water in the heating tank even when I know it is empty. Because of this, the...
You could be correct in your assessment and if so, as long as the device is under warranty it needs to go back for servicing. If you open the chambers, the warranty is Void and the device a boat anchor.
Jan 21, 2014 | Keurig K10 K-cup Mini Plus Coffeemaker...
Will not brew says it is ready
TRY...1. Lift up the water reservoir and drop it back into place. There is a magnet that has to be in the right position and putting the reservoir back into place causes it to go back where it should be.
2. It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Nov 10, 2013 | Keurig Special Edition B60 Coffee Maker
Water will not dispense on my Keurig Vue .Brewing process stops after a couple of seconds
RINSE:
Sep 29, 2013 | Keurig Vue Brewing System
When I hit brew, it sounds like its going to brew and stops right away.
RINSE:
Aug 15, 2013 | Keurig Platinum B70 Coffee Maker
Keurig mini keeps asking to add water
Needs cleaning and reset the system with a full flush and Calc.
Feb 04, 2013 | Keurig B31 Mini Plus Brewing System
Coffee maker is indicating not ready add water
May 23, 2010 | Keurig B60 Coffee Maker
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
Keurig B50 Coffee Maker Logo
211 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
