Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Where is the high temp sensor on the 8003-xspa B6x
3 Suggested Answers
SOURCE: I need a repair manual for a 8003-xspa. Or advice
how much money per month to run the 8003 eclipse dream maker spa?
Posted on Apr 13, 2011
Coastsider
  • 331 Answers
SOURCE: I have a dreamaker 8003 xspa that has worked perfectly over the many years that I have had it. The other day I noticed that the water had lowered 6 inches overnight an the water was coming out of the
1. Check equipment like pump, heater, blower, light fixture, for leaks.
2. Remove side panels closest to the are the leak is showing and inspect jets, plumbing in that area for leaks. If insulation is foam, remove any water saturated foam and follow it to the source of leak.
3. If the leak is in plumbing and is very slow, sometimes it can be resolved with "stop leak" products.
Posted on Aug 15, 2012
Temp and high temp sensor install location . dream maker spa
There should be a tiny ink dot somewhere on the sensor high temp would have a lil red dot n the low temp should have a lil blue dot. N on the tub the top one is high temp if I remember right
Nov 23, 2015 | Pool & Spa
Aug 07, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Saber que es codigo 15 codigo 20 y codigo 25 isuzu trooper mod 1988 gasolina 2.600 cc. inyectado
Revise estos codigos correspondientes al sistema OBD I...
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 EGR system fault
33 MAP sensor circuit (signal voltage high, low vacuum)
34 MAP sensor circuit (signal voltage low, high vacuum)
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 PROM error (faulty or incorrect MEM-CAL).
Suerte.
Apr 18, 2011 | 1987 Isuzu Trooper
What is code 23 for pontiac grand am is it vacume leak
Wow these are hard to find!!
Diagnostic codes for 1987 Pontiac
32 Exhaust Gas Recirculation (EGR) Vacuum Control
33 Mass Air Flow Sensor (MAF) (GM/SEC High)
34 Mass Air Flow Sensor (MAF) (GM/SEC Low)
41 Cam Sensor Circuit
42 C3-I EST or Bypass Circuit Failure
43 Electronic Spark Control (ESC) Circuit
51 PROM Error
52 CALPAK Error
55 ECM Error
If you have your owners manual they should be in there. I couldn't find one online but did find this.
Future reference
http://autorepair.about.com/library/ts/obd-i/bl-dtcs-28.htm?once=true&
I hope these helped you
Nov 26, 2010 | 1987 Pontiac Grand Am
Radiator fan not turning on time
Check the rad fan fuse or the relay under the hood.
Is the temp going too high? Check and make sure you are not low on rad fluid (engine cool). An air pocket where the fan temp sensor on the rad is located will not activate the sensor.
Failing that, check the rad temp sensor which activates the fan. If this sensor does not close at high temp...the fan won't work.
Aug 17, 2009 | 2001 Hyundai Santa Fe
Replaced high temp sensor on whirlpool front loader
The high limit thermostat should have been replaced also.
If there are no obstructions that will fix your problem.
Mar 13, 2009 | Whirlpool GEW9250 Electric Dryer
Printek 8003 printer gets false paper jams when trying to load from any one of the three tractors. We have changed the paper out sensor, edge sensor, power driverr pwa, logic board, and backplane.
Have changed out the Jam detection sensor? That is the black paper guide with a wheel in the center of the assy?
If you have any questions please contact me we offer free technical support and carry all parts for Printek units New and Refurbished.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
3821 W. 127th Place
708-597-4222 x24
rcardenas@mrp.to
AOL IM: RORYMPR
Mar 05, 2009 | Printek FormsMaster 8003 Matrix Printer
Car keeps dying
Trouble Code 33 and 34 are the MAF/MAP Sensor Circuit. It sounds like you've replaced that sensor already. Did you also have the code 34 before putting in the new sensor?
Or did this code start after it's replacement? Any other codes appearing?
Troubleshooting it would depend if it has the Speed Density Update. The dealer should be able to provide that info.
Here's your fault code list:
13 oxygen sensor circuit 14 coolant temp sensor circuit (high temp) 15 coolant temp sensor circuit (low temp) 21 throttle position sensor (TPS) circuit (high signal) 22 throttle position sensor (TPS) circuit (low signal) 23 manifold air temp (MAT) circuit (low temp) 24 vehicle speed sensor (VSS) circuit 25 manifold air temp (MAT) circuit (high signal) 31 wastegate solenoid electrical circuit 32 exhaust gas recirculation (EGR) circuit 33 mass air flow (MAF) circuit (gm/sec high) 34 mass air flow (MAF) circuit (gm/sec low) 41 cam sensor circuit 42 C3I EST or bypass circuit failure 43 electronic spark control (ESC) circuit 44 oxygen sensor circuit (lean exhaust) 45 oxygen sensor circuit (rich exhaust) 51 PROM error 52 calpak error 55 ECM error
Aug 07, 2008 | 1989 Buick Regal
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
77 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
