PS2342257 WIRING DIAGRAM
TRANSISTOR ON CIRCUIT BOARD
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: Viewsonic VX924 monitor SMPS failed. Replaced all
When the DC filter caps no longer filter out high frequency AC, that AC will be fed through out the circuits and cause damages such as the inverter frequency will be running at the wrong frequency and caused overheating.
The service manual does not show the sch of the power supply/inverter board because it is not designed by Viewsonic.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX924/
Posted on Mar 27, 2011
2004 ford freestar 3.9lcode po305.replaced plugs wires coil and egr .still has code po305
Egr wouldn't have anything to do with it , not just one cylinder . Is the fuel injector firing ? Do you know how to test a computer driver ? ( transistor ) Injector Circuit Wiring Diagram How to test fuel injector circuit with basic tools open control wire
Jan 10, 2017 | Ford Cars & Trucks
I need circuit digramm for elektronic board to AEG tumble Dreyer 56840L
Request the schematic diagram directly from AEG.
Aug 23, 2016 | AEG Dryers
Where can I get the scematic for the Veco 21 STC voltage control circuit board?
try mailing the manufacturer
hot transistors are usually shorted out, or driving a short!!
a multimeter across the 3 transistor legs (TO-3 transistors have 2 legs & the case which is the 3rd leg) will reveal if they're dead (remove the transistors first as the circuit may give a false reading) - if you get a zero ohms reading between any of the legs it's dead - don't forget to check the smaller driver transistors too,, as a dead main transistor will kill its smaller driver transistor
speakers are marked,, usually 4 ohms or 8, though sometimes 16 ohms - use a multimeter to ensure you have something very close to these values according to the label on the speaker box & measure from the wires at the point where they connect to the amp
power the unit without any speakers or speaker wires connected,, if the transistors still get hot, you're very likely looking at bad transistors
Feb 21, 2015 | Audio Players & Recorders
Ya240a mig welder
You can find all the century manuals and diagrams at this page:
http://www.lincolnelectric.com/en-us/support/pages/operator-manuals.aspx?q=wire+feed&type=text
Just click on it or copy and paste on your web browser.
Jan 15, 2014 | Welding Tools
Genius gate electrical diagram
If you do not have a schematic of the device the best advice is to go online and try to find a service manual for the exact model of your device and this will provide you with a part number. Remember transistors usually do not fail by themselves they fail because something in the same circuit shorted out to cause the transistor to fail.
Nov 14, 2013 | Computers & Internet
Wiring the circuit board i need a diagram
wiring diagram for what brand? is the circuit board located in the pump housing or in a separate box?
Rod
US Parts Center
We locate the "seemingly" impossible...
888-521-6183
Jan 20, 2013 | Home
Viewsonic VX924 monitor SMPS failed. Replaced all bad capacitors and have found that one pair of inverter driver transistors has failed. They are marked as DKQR (They are apparently Rohm 2SC4672...
Mar 27, 2011 | ViewSonic VX924 19" LCD Monitor
Power on but no click sound. found some transistors and resistors burn in a small board located at down side of the amp, need scematic circuit diagram to repair it. Please send.
If you have burnt the transistors that are located on the circuit board, then you wont be able to repair it I dont think because in the circuit board there are probibly mulitple layers of electrical wires the are extremely small and fine that would make it impossible to connect the transistor to the right layer. Try contacting the manufacturer though
Oct 08, 2009 | Audio Players & Recorders
Sylvania tv
I know your problem for sure. If the fine line you are seeing is horizontal, you have a bad capacitor (or cold solder joint) in the "vertical deflection" circuits. Look for four of the largest wires coming from the picture tube and follow them down to the circuit board. These wires do NOT come out of the BACK of the tube, where most of the wires come from, but rather come sort of from the side of the tube. Two of them will go down to the board near the largest component on your board known as the "flyback transformer". Disregard these two and follow the other two. They will go near either two transistors or a vertical deflection chip. The board will normally be labeled "vertical" or vertical deflection near these transistors. There will be two or more capacitors very near these transistors. Look at them on the underside of the board and look for a bad solder joint. Push on the capacitors left and right while observing the underside of the board and you might be able to see the bad joint. If it is a chip instead of transistors, you could still have a bad capacitor or cold solder joint, but in most cases if it's a chip, then the chip is bad. Since, however, you can tap on the tv and make it work temporarily, this tells me that you probably have two vertical deflection transistors with associated capacitors. If the caps are good and no cold joints, then replace the transistors. This part of your tv is what pulls the electron beam up and down vertically and is thus called the vertical deflection circuits. With no vertical deflection, then the beam just moves left and right and never moves up and down. The picture is still there, but it is contained inside the fine line where of course you cannot see it. The parts in this circuit are not expensive at all. Keever
Mar 03, 2008 | Televison & Video
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
