Question about Acer Aspire Computers & Internet
Cant find the picture rotation button - Aspire Acer Computers & Internet
  • Acer Master
  • 5,660 Answers
It's right next to the 3D button.......
..........KIDDING...........
Press the CTRL, and ALT key down, and at the same time tap once on the UP arrow key.
Tap until the screen is in the correct position
Regards,
joecoolvette
Posted on Apr 19, 2013
Where can i find the picture rotation button on a acer spire 5250 computer
To rotate what picture? If you want to rotate the desktop you only need to right click on the desktop and select the "Rotate" button.
Apr 18, 2013 | Acer Aspire Computers & Internet
How to save photo after rotated
If you use "Windows Picture and Fax Viewer" you can use the rotate buttons on the bottom of the program. And then simply hit either the left or right button and this will save it for you.
May 04, 2011 | PANDIGITAL 7-Inch Digital Photo Frame with...
My screen's pictures are shifted to the right. how do I fix it or get it repaired?
Do you mean you need to rotate the picture?
Just open the picture in Microsoft Picture Manager, select Edit Picture and then click the rotate button.
Alternatively, you can download IRFanview, a free application that lets you edit your photos faster and better.
http://irfanview.com
Mar 12, 2011 | Vivitar ViviCam X029 Digital Camera
I look at my self and i cant see my self and its
hello
You can focus the picture by rotating the ring around the lens of the web camera it rotates, to both directions it will max out at somepoint and then it will not move more to that direction instead try the other direction then.
Jun 08, 2010 | Microsoft LifeCam VX-1000 Webcam
Cant program radio code renault scenic
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
Apr 11, 2010 | Car Audio & Video
The picture is on a slant. I haven't got a manual as it was second hand. I have the remote but I cant work out how to change the picture settings
It is possible that in the menus there is a setup that has picture rotation. But for this model, I believe there is no rotation option. You will have to go through the menus to see if it is there. I would start in the video, or the picture setup menus. Press menu on the remote to go in to the menu. Use the arrow buttons to move through the menus.
If there is no rotation option, this means the deflection yoke has been turned or was never strait from the manufacture. Yoke rotation is not something I would advise for you do yourself. If you rotate the yoke, there is the possibility the set will require a complete re-convergence and purity setup. You will have to have the training, and the required pattern generator to perform these adjustments.
You could call an experienced TV service man, especially someone who has a lot of experience working on Sony. This type of tech should know what to do to fix your problem.
Jerry G.
Nov 14, 2009 | Philips 28PW8608 28" TV
Cant put the code in
===================================Philips Renault Code Entry
Use the steering controls for code entry.
Press the [¬ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
press and hold the [¬ ] button for up to 10 seconds to store the code
Feb 20, 2009 | 2000 Renault 181
Viewing pictures on camera
When you rotated pictures you changed picture size and definition, that is the reason why camera does not display them again.
If you check file size, you will see that rotated pictures are smaller than regular ones.
There is no way to get picture to original definition once you reduce it, however if you use a program like Photoshop you can check size and definition on original pictures, and re-rotate and resize rotated pictures to send them back to the camera, quality will be poorer than originals. Attributes to check are length and width (preferably in pixels) and definition, then you save pictures as best quality.
Aug 09, 2008 | Panasonic Lumix DMC-FX12 Digital Camera
Malfunctioning of Nikon 2100
I had the same problem.The shutter button is faulty and is always half pressed - auto focus is operational (this is the step before actually the picture is taken. Try to clean it up with some special electrical contact spray. if this does not work - need to replace it - Not a simple job for the novice. You might need to take the camera to a service center for a spare on-off-expose button. I had an old faulty camera where I took the button from it. That solved the problem.
Nov 27, 2007 | Nikon Coolpix 2100 Digital Camera
Slow shutter speed
from the manual: Using Shutter-Priority Mode 1. Set the mode dial to S (shutter-priority) and a yellow arrowhead on the screen points to the current shutter speed. Press the jog dial and the current shutter speed turns yellow. 2. With the current shutter speed displayed in yellow, rotate the jog dial to select the speed you want to use. 3. Take the picture. If a workable aperture isn?t available for the shutter speed you?ve selected, the shutter speed indicator on the screen flashes when you press the shutter button halfway down. You can use the setting as is, or press the jog dial down to select the shutter speed again and rotate it to select a new shutter speed.
Jun 03, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Computers & Internet Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
