Question about Electrical Supplies
What does carb look like?
Where is the carb located on a powermax genereator? behind air filter?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 41 Answers
Between air cleaner and engine or possibly in PRC if you got screwed when you bought it.
Posted on Jul 04, 2013
Where is air filter located?? Also, what is plug gap setting for NGK plugs for this bike??
NGK BP8ES or equivalent with a gap of 0.7~0.8mm (0.028~0.031in). This might sound crude but the air filters are behind the carbs. Watch thus youtube video, you need to remove the seat, both side covers and undo the rear tank mount.
https://www.youtube.com/watch?v=McqgLkJ7Hk8
This will help. Rod
Aug 04, 2015 | 1985 Yamaha XJ 700 X Maxim
Where is the fuel filter located?
What kind of mower ??? Most 21" walk behind mowers ONLY have screens in the tank
Most riders have an inline filter
ALL commercial mowers have an inline filter
inline means it's in the fuel line going to the carb
Apr 12, 2015 | Garden
Need diagram of a MTD walk behind mower with honda 160cc engine with ARCS option
Remove air filter cover. Remove air filter. Remove the 3 10mm screws mounting the air filter housing assembly and carb to motor. You will need new gaskets to install the new carb. Gaskets: 16221-883-800 2ea., 16212-ZL8-000, 16228-ZL8-000, and the gasket for the back of the air cleaner mount 17228-ZMO-000. You can buy the carb for these on line for about $14, 16100-Z0L-023. Most take a NGK PLUG BPR6ES.
Apr 02, 2014 | Garden
Lawn mover 550 ex won't start
Its most likely your carburetor (located behind the air filter). You can try to spray carb cleaner into it or take the carb apart and clean every hole. You used gasoline and not diesel right?
May 11, 2013 | Garden
Huscqvarna 130 bt backpack leaf blower getting 70%output new plug new. oil mix50/1 ,air intake clear ,fuel filter off now,carb cleanersprayed in choke,notice small oil discharge underexhaust CANT FIND a...
The oil tou see under the exhaust is normal.make sure air filter is clean.you should put a new fuel filter on.it is important to not run it with fuel filter off it will **** up any dirt that is in the tank and end up in the carb.you are probably going to have to rebuild the carb and clean it out .
Nov 23, 2010 | Garden
Air filter location
under the gas tank gas tank has to be removed
Mar 17, 2010 | 1996 Yamaha Royal Star XVZ 1300 A
I have a 1987 commercial lawnboy walk behind mower that has stopped running. I gradually lost power over the summer and now it will not start. I have installed a new plug and filter earlier in the spring....
I would try and remove carb and clean it thuroughly. You can soak the parts in solvent or equivelant. The carb would be right after the air filter tube to the intake of engine.
Aug 25, 2009 | Garden
Powermax water pump shuts off after 5 min or more
Either the coil/HEI module is bad or your on/off switch(kill switch) is bad. Check those first.
May 19, 2009 | Powermax XP650WP Portable 3' Water Pump...
Where do you locate oil filter on a 2003 mercedes c180
KOMPRESSOR ENIGNE?? IF SO CHECK BY THE FIREWALL DRIVERSIDE. ITS A THIN FILTER CAP , HAS A BLK 27MM PLASTIC ALMOST NUT TO REMOVE OIL FILTER.
Apr 10, 2009 | 2003 Mercedes-Benz C-Class
Throttle body in 2001 Passat
throttle body is located at intake manifold ..follow snorkle from air cleaner to where it attaches to motor ..looses hose and clean with carb cleaner there..open blades(throttle) to get behind entry good also..... fuel filter is located in tank and in line from fuel tank just in front of tank inline with fuel line...good luck
Dec 15, 2008 | 2001 Volkswagen Passat
Electrical Supplies Logo
13 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
