Question about Horizontal OHV Engine 390cc, GX Series, 1in. x 3 31/64in
I have an older model Powermate 8125 watt generator with a Honda GX 390 engine. The unit has been setting up for 4 years so I disassembled the carburetor and soaked it in carb acid. The main jet was c
Any suggestions are welcome.
    Champion:
    Scholar:
  • 227 Answers
Clean all the ports and jets with some torch tip cleaners or mechanics wire cut at an angle to be sharp.
Make sur ethe fuel filter is not clogged, or the sreen in the tank.
Also empty the tank and dry it out, then add fresh fuel as gasoline goes bad.
Posted on Oct 24, 2013
Ihave a honda generator with a gx 390 motor volt drops when i put a load on it what could it be
Voltage regulator, carbon buildup in the cylinders, the carburetor may need overhauling, engine governor may have a stretched spring, Spark plug may need replacing, Timing may be off, air filter may need changing, and lastly, your load may exceed the ability of the generator.Checking this list will uncover the loss of power
Oct 20, 2016 | Honda Electrical Supplies
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Do i mix oil in the gas on the coleman powermate 8750 honda 13 hp?
Hi, no you don't. It is a four stroke engine and uses engine oil in the sump only. Regards Phil.
Jul 28, 2011 | Coleman Powermate 7,000 Watt 13 Hp...
When checking the oil on the motor should the dip stick be screwed in for the correct oil level or just setting in the hole??
For Honda engine, just set in opening (unless it has a push-in dipstick like on auto ),
Briggs, most models, and other brands best to thread in unless stated in manual.
If oil cap is very close to base of engine and does not have an oil level marker, then fill to top thread (many older engines that did not have oil senser).
Dec 16, 2010 | Coleman Powermate Powermate 5000W...
Where can I find an owners manual for a Black Max 8125/ Honda GX390 OHV generator? I searched Honda's site but not there, no black max site. My lawn guy pulled a wire off and I need to see where it is...
low oil sensor will not cause the motor not starting.
most likely is th ground wire.
you can try to attach that wire to any surface and try to start it. of it start, then you have to dis-assemble the head and find out where the wire should be attached.
if not, the wire is attached to a hot side. either way you have to dis-assemble the head.
http://www.honda-engines.com/engines_owners_manuals/ownersmanuals/gx390.htm
here is the site for the manual.
Apr 07, 2009 | Electrical Supplies
5000 watt generator no juice
most generators have a reset button. check your manual under the trouble shooter section good luck.
Jan 26, 2009 | Coleman Powermate Premium Plus 6250W...
Horizontal OHV Engine 390cc, GX Series, 1in. x 3 31/64in Logo
96 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Spud Howell
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
